Remote Desktop
Instructions
1. Telnet in
- mkdir /media/gbin
- cd /media/gbin
- wget http://dl.dropbox.com/u/279536/rdesktop
- wget http://dl.dropbox.com/u/279536/libsamplerate.so.0
- chmod a+x rdesktop
- export LD_LIBRARY_PATH=/media/gbin
- export DISPLAY=localhost:0
- ./rdesktop 192.168.10.201 -f -u USERNAME -p PASSWORD
and rdesktop popped up OVER the juggler OS, with touch screen working and everything... :D
(the wget files can be lifted from your own ubuntu installation if you would rather not download random binaries... the export LD_LIBRARY_PATH tells it to look in that dir for .so file (the linux .dll's) The export DISPLAY tells it to connnect to the xserver on the juggler itself The -f means fullscreen in the rdesktop command
To kill the rdesktop session, either logout through windows, or press ctrl+c on the telnet session.
todo: Try to make it able to be kicked off without using telnet, so it boots straight into a rdesktop session... shouldnt be too hard.
Some Errors
- ERROR: Failed to open keymap en-us
WARNING: rdp_out_unistr: iconv_open[ANSI_X3.4-1968 -> UTF-16LE] fail 0xffffffff roblem is that my remote desktop is not enabled... retried and worked as charm !
- The error about ERROR: Failed to open keymap en-us
is because a 'proper' install of rdesktop includes different keymaps for different keyboards, and i didnt lift them (it doesnt matter as the joggler lacks a keyboard... might make a usb keyboard act like a american one instead of british etc tho)
- The error WARNING: rdp_out_unistr: iconv_open[ANSI_X3.4-1968 -> UTF-16LE] fail 0xffffffff
I dont have a clue! but it seems to work. Im guessing its converting ANSI to UTF somewhere and encountering an illegal characters... doesnt seem to stop it working tho...
- WARNING: Remote desktop does not support colour depth 24; falling back to 16
This one is self explanatory...
