Ok, so I started last night, foshiz mini v2 is coming along, and with the audio fix from the hipda forum, should be almost error free apart from the NIC issue, the only issues you may find once I finish tinkering is the touch screen not working, This is thanks to the fact I build my images on an Openpeak joggler, previous builds someone(usually Mevi or Pete,
) has kindly run them on their o2 joggler to fix the issue and reuploaded for me, looking into maybe adding the old startup script back into the images to hopefully resolve the issue, as on my earlier builds the script being present used to fix this(iirc). Also looking into various launchers and explorer replacements, aswell as trying to make Foshiz mini "protected mode" using either ewf or another partition protection method, ewf seems to be the likeliest to succeed. Not saying when the image will be available, but coming soon should do it! lol.
Also I was away from the forum quite a bit lately, I am back now, and will probably be back to the old ways
