Radio feed playing x2 speed on Lounge and Squeeze - FIXED
Hi there,
I'm having a problem with the following radio feeds (Disney MouseRadio - not my choice - honest! :D)
http://38.96.148.91:4152/
Alternative http://db.tt/p5j85e5
playing at double speed in both the Lounge Radio app and Squeezeplayer on the stock OS. Other stations are fine so I'm guessing it is a problem with this particular SHOUTCAST stream being 56kbps. Is there a fix for this? I've tried to find alternative urls but they all have the same problem so I'm guessing it can't be done.
EDIT: I've also tried playing through TuneIn app and Shoutcast app on Squeezeplayer, but again it's all double speed Chipmunk world!
Re: Radio feed playing x2 speed on Lounge and Squeezeplayer
And of course, as is usually the case, I spend three hours tinkering, post on here and then fix it by googling and arriving here http://www.jogglerwiki.com/forum/viewto ... &t=54#p520! Sorted by going into PnP and selected Internal Mixer + Soundcard option. Reboot and all is good!
Jarv_77
Re: Radio feed playing x2 speed on Lounge and Squeeze - FIXE
Post by Jarv_77 »
So, out of interest, do you use a usb sound card or is the pnp setting just overriding something else? My o2 app lounge radio stations play chipmunk too, just wondering if I can fix it with a change of pnp settings or if I need a usb soundcard!?
Nah, no USB soundcard - just the standard internal sound. No idea why the fix works. It also fixed an issue I had with the volume being quieter than I thought it used to be too!
Utakos
Post by Utakos »
Does anyone know how to fix this without installing p'n'p, Clean installed Squeeze box + server and thats all I require, do not really want to go down the pnp route again?
