XP is definitely waaaay better on a HDD.. the slow small file write speed on a SD card or a USB stick will make life miserable for you. You won't be able to power a HDD on an unpowered hub.
I suppose I should plug my XP build, which I use myself on a 24/7 network streaming Joggler. It's very hard to kill, I've found. Just uninstall anything that doesn't interest you.
Have a good read about the outstanding problems with XP in post #1 of my build 3 thread. It might be that you'll want to keep that internal WIFI for syncing the time (the joggler doesn't have a battery powered clock) if the Ethernet doesn't work on your particular Joggler. Currently, sound is limited to working on BOTH the speakers and headphones simultaneously, or use the alternative drivers posted and put up with low level digital fizz from the speakers (or you can cut the speaker wires).
Hi All
Yes i agree with Mevi XP is best on HDD mine's been running for weeks with no problem at all.
My joggler config is. I have removed internal wifi card and put it on a usb hub using the one usb port outside.
Then mini drilled a hole in back of joggler case so the usb cable come's out side in to usb HDD.
The HDD i am using is from tesco a 320gig toshiba portable harddrive it's usb powered.
Hope this helps.
Many Thanks
Andrew
