Kodi (Formerly XBMC) Dev/Beta Builds
Rather than reposting this on multiple threads, I thought it would be best to start a thread here.
I am uploading XBMC Development Builds to my joggler-testing ppa. These are designed to work with any of the Linux distributions from http://joggler.exotica.org.uk
Current Release KODI 14.1rc1 (Helix)
To try the latest build:
sudo apt-add-repository ppa:jools/joggler-testing
sudo apt-get update
sudo apt-get install kodi
Re: XBMC Dev/Beta Builds
Note: Frodo Beta 2 is uploaded and will be available on the PPA soon.
frodo beta 2 now available.
Must check this out tomorrow... :)
Frodo beta 3 is now uploaded.
Frodo RC1 currently being uploaded. Should be available soon.
Frodo RC1 is now available.
craig_1234
Post by craig_1234 »
Do these builds support hardware acceleration for 1080p playback within XBMC?
Vaapi works for some formats but 720p is the max in xbmc really. Mplayer-vaapi on joggler can do 1080p
I put Jolie on one of my Jogglers. Very nice! Testing your new XBMC builds. I've been "testing" the new XBMC builds on a couple of other machines in the last couple of weeks.
Writing this post to validate my configs.
Edited sources located at:
/etc/apt/sources.list.d/joggler.list
this morning to:
I did not have a /etc/apt/preferences.d/joggler.pref file but rather an 05-Joggler file under preferences dot d and I edited it such that:
/etc/apt/preferences.d/05-joggler
reads:
Package: *
Pin: release o=LP-PPA-jools-joggler
Pin-Priority: 1010
Package: *
Pin: release o=LP-PPA-jools-emgd-xorg1.9
Pin-Priority: 1010
Package: *
Pin: release o=LP-PPA-jools-joggler-testing
Pin-Priority: 1010
Update took a while; worked fine though.
Install of XBMC was fine.
Updated the NTP time stuff on the build to sync with my internal time server.
Tested XBMC with just the video and music NAS stuff to work well.
Very nice!
Might move the build over to an SSD to USB drive as I have a few of those around now.
aah yeh, the preferences file is differently named on jolios, as they have other pin files and the order matters. That all sounds good and thanks - should be useful to others.
Thanks Buzz,
Working well here.
I haven't yet tried the PVR / streaming pieces as mostly its all HD right now. I am though setting up an "in-house" SD channel via a third tuner to see how that works.
Frodo RC2 is uploaded/building and will be available shortly
MarkGrld
Post by MarkGrld »
Any chance of looking at a google music plugin?
I've been trying to get this to work - http://wiki.xbmc.org/index.php?title=Add-on:Gmusicapi but no joy yet.
cheers
Mark
MarkGrld wrote:Any chance of looking at a google music plugin?
You would be better of asking on the xbmc forum regarding specific plugins etc.
Happy Xmas btw (in 2 hours here)
Frodo RC3 is currently being uploaded and will be available soon.
Currently building/uploading final of XBMC 12 - Frodo - I will also make it available on the main joggler ppa soon after.
Buzz,
Would XBMC fit on the 2Gb flash drive in the Openframe2 boxes? Would it be too slow?
with a small enough distro (like the ubuntu base + xbmc one from this forum), it should fit. Not sure about speed though.
I am thinking then could I boot up in your Mint build copy over the xbmc build to the flash disk a little bit at a time?
I am guessing here and it would be more just to see how fast it worked off the built in flash? (start with EFI as I know that it wouldn't work right now with the seabios/coreboot bios stuff). For whatever reason right now I have the Openframe 2 box booting very well off this 12 port USB hub with a bunch of stuff on it really fast though.
I would start maybe first writing the build to a USB stick; shrinking if necessary using GParted; then DD'ing the USB build to files then writing the files partition by partition over to the flash memory while running your Linux Mint build?
