I'm guessing Spotify works fine on 10.10 using Wine. Just seen the install instructions based on 10.04 and assume 10.10 will install the same way?
Also I use a Spotify Remoteless Helper application on my windows laptop which enables me to use my iPod Touch to controll Spotify on the laptop. Could I install this application on the Joggler too?
Matt
Spotify - Ubuntu 10.10 (Maverick)
Re: Spotify - Ubuntu 10.10 (Maverick)
Spotify does work pretty well under Wine. It's not the fastest in the world, but it does work. Not sure about the Remoteless app though - you would have to try it.
There's also Spotify for Linux and Spotify for Squeezebox too.
