Editing config files on the Joggler
Darkmatter
Post by Darkmatter »
I want to edit some config files of my joggler which is running the latest firmware and PNPIII. I can SSH in to the joggler but I'm not sure how to edit the config files. I can't find nano or vim which is how I would normally do it on linux.
Thanks,
Dave
multiplex
Re: Editing config files on the Joggler
Post by multiplex »
you should be able to use the busybox vi and if you know vim you might know how to drive it...
Darkmatter
Hi multiplex,
Thanks for your response. Got it all working with your help.
Dave
