dead flash!
dead flash!
Dramatic title, but actually nothing too serious.
My flash is dead, but not the internal flash :)
One of the first USB stick's I bought for use with my Jogglers has died. It has been in constant use for a couple of years though. Looks like an identical replacement will put me back £8. Certainly cheaper than a new Joggler, had I been using the internal flash and that had gone.
Re: dead flash!
it looks as though it might be under warranty as it's listed as a "limited lifetime warranty". Maybe I should try returning it ;-)
Re: dead flash!
Try flashing this image to it https://dl.dropbox.com/u/1107587/bootsector.img - it has brought a few flash drives back from the dead for me!
Re: dead flash!
it's dead in a way that it cant be probed sucessfully by the os so there is no device to write to. but thanks anyway :)
Re: dead flash!
As you've all ways stated, better to use an external flash then the internal ! I wonder how long the internal would have lasted if used in the same way as your USB stick ? Two years of continual use just goes to show how resilient flash can be !
I used my first big flash drive just like a hard drive as I didn't appreciate the limitations of it at the time and it eventually failed on me. When I plugged it in the LED would not light and it was not recognised by Win XP. So I went to a Russian website (see below) and tried a solution from there. It recovered the drive - there are some dodgy sectors on it, and it now has a different name - but better than having a dead stick ! In fact I still regularly use it and it has been fine for 5 years since being reincarnated.
You might like to have a look at these :
39 - How to repair your USB Flash drive - RMPrepUSB
http://www.rmprepusb.com/tutorials/repa ... lash-drive
Google Translate
http://translate.google.com/translate?h ... e%3Diflash
How to Repair a USB Flash Drive: 17 steps (with pictures)
http://www.wikihow.com/Repair-a-USB-Flash-Drive
