I am now on my second Joggler.
Joggler The First worked just fine: used mainly as a photo display with Google calendar underneath. The photo screensaver worked nicely: the time between photos could be set to whatever period I wanted. Then the unit died and could not be recovered whatever. Eh, these things happen.
So, Joggler The Second was bought. This one seemed to be identical. HOWEVER: the photo screensaver cannot be modified to change the delay. Photos change every 3-4 seconds, far too quickly. As far as I can tell, the unit is running the most up to date firmware.
1. Does anyone else have this problem?
2. Can I fix it?
photo screensaver delay, why you not work?
Re: photo screensaver delay, why you not work?
Yes i too would like to patch the delay!
I think it is located at /openpeak/gui/apps/o2_settings/main.swf
BUT i can't find a way to edit the .swf files !!!
Anyone???
Anyone???
