wrong power supply
Jonathan Bowley
wrong power supply
Post by Jonathan Bowley »
moved house and lost the joggler power supply, so was using one from a virgin telly box... worked a treat it did.
subsequently found the original power supply and asked the OH to pass it to me at the end of a long day. she handed me a linksys router power supply which i plugged in without batting an eyelid... the joggler screen lit up for about 2 seconds and promptly died. the smell was quite something.
so, the question is, can the joggler be resurrected?
Re: wrong power supply
Oh dear - time to replace your Joggler and the OH :-)
If you're lucky it will have just burnt out an internal fuse but if you smelled burning it has probably gone beyond that. You'll need to disassemble it & have a look inside.
wrong power supply
Ooh, dear. Sounds bad. But, get it open and take some pics. Perhaps we can offer some advice.
Poor you Jonathan :'(
there is a post on here recently with a cracked screen joggler for sale , might be a quick fix for you assuming the screen is ok on yours .
wrong power supply
hawsey wrote:Poor you Jonathan :'(
That's good thinking. With any luck you could just swap the screens - an easy job to do.
