Joggler not working
perrard69
Joggler not working
Post by perrard69 »
Hi there. A complete novice here, who recently purchased a 'pimped' up joggler off ebay. It seemed to be working fine for the past week using the lolicloud os. However, I noticed that there were about 156 oustanding updates, so I clicked to update them. Since then, it just hangs at the opening lolicloud screen.
Any ideas on what I can do?
I do have a 4-way hub, usb stick and keyboard plugged into, so can do some basic hacking if anyone can tell me what to do in simply terms?!
Many thanks
Andrew
Re: Joggler not working
It probably broke a few things when updating
Download a new version from here: http://joggler.exotica.org.uk/jolicloud/
And download win32 disk imager from here: https://launchpad.net/win32-image-writer/
Then use win32 disk imager to write the new image you downloaded earlier, you will need to unzip the image you downloaded.
probably had a very old vesrion of jolios on it. you should be able to safely update with the latest image anyway.
perrard69
Post by perrard69 »
Thanks all. Will give it a try and see what happens!
