Worth losing the wifi for an SSD?
jonke
Post by jonke »
I have a spare SSD (early OCZ Solid 32GB). Given the suggestion made elsewhere that you could lose the external USB key protuberance by relocating it inside the slot currently occupied by the wifi card, and given that I'll probably be making use of a Homeplug ethernet connection, what do people think of using the SSD which has a mini-usb socket?
I currently have a USB keydrive with Joli OS 1.2. Would a 32GB disk lend itself to better implementations than Joli?
I think I will mostly be using the Joggler as a Squeezeplay client.
Regards
Jonke
nitrowing
Re: Worth losing the wifi for an SSD?
Post by nitrowing »
I would think that 32Gb would be overkill for the Joggler - have you had a look for a broken Asus Eee to rob the SSD?
jonke
Post by jonke »
Funnily enough, I just replaced the SSD in my Asus eee901 so I have the original lying round. How would I connect that though? It's not USB is it
