Been playing with UPNP on the Joggler with the original OS. I noticed it works fine with the NAS music shares but doesn't play back any of the network feeds. I do have TVersity configured for transcoding. I read some where about the Joggler using version 1 of UPNP.
Anyone know if there is a TVersity profile for the Joggler?
Joggler OS UPNP for TVersity Profile
Re: Joggler OS UPNP for TVersity Profile
Network feeds as in internet radio?
Yes; the same feeds work on the PBO NMT. On the Joggler the network feeds just touch on each one then proceeds to to go the next one until the last feed with none of them playing.
TVersity log shows:
http://www.bbc.co.uk/worldservice/meta/tx/nb/live/eneuk.asx
http://www.bbc.co.uk/worldservice/meta/tx/nb/live/eneuk.pls
Error - Could not get url http://www.radiofeeds.co.uk/ws.asx
Error - Could not get url http://www.bbc.co.uk/worldservice/meta/tx/nb/live/www15.asx
Will have a look around for you pete!
Thanks Dan.
While I was writing kept changing type of TVersity connected devices from automatic.
I changed it to an MP3 device and it worked. Now though I get "pops" and "clicks".
That might be tversity transcoding on the fly, what system do you have it running on?
TVersity is running on a core duo along with PlayOnTV. It does OK.
Hmmm, could not find anything, will kepp looking, about time I gave the Google fu some a work out!
