Squeezeplay image for internal mmc / usb
Wilberforce
Post by Wilberforce »
Not sure if this any use to anybody but I've created an image of my dedicated squeezeplay install for the internal mmc. It is based on Buzz's ubuntu 11.04 and Roobarbs squeezeplay (with a few tweaks). It uses my network applet for squeezeplay which should handle autoswitching to wired, autoreconnecting etc (see here)
You can grab the image here.
Just uncompress the image (with unxz or similar), stick it on a usb stick containing a joggler bootable GNU/Linux distro and copy to the mmc:
mmc instructions:
first check the md5 of the uncompressed image(squeeze-11-04.image):
md5sum squeeze-11-04.image
This should be:
14a309f6e6e4fc4547aa4087d95334b0
Then copy:
dd if=squeeze-11-04.image of=/dev/mmcblk0
Probably wise to backup your original mmc image. Oh yeah, I should probably mention that everything is at your own risk :D
usb instructions
uncompress with 7zip or unxz
burn uncompressed image to usb key with dd or win32diskimager
Edit: as pointed out by gadget_hunter you can also put this on a usb stick.
kroonen
Re: Squeezeplay image for internal mmc
Post by kroonen »
It's bootinbg, i get wireles connection ut it fails to connect to mysqueeze
So i thought login over ssh , but username joggler password joggler doesnt work. What is the acount for it?
regards Richard
Wilberforce
Opps, forgot to mention that...
username: ubuntu
password: ubuntu
Wilberforce
Have you tried adding the IP of your squeezebox server in settings > advanced > networking > remote libraries > add new library? Or are you getting stuck on the welcome setup?
kroonen
Post by kroonen »
OK, I can connect to it. Networking is ok I can ping to mysqueezebox.com, but with squeezeplay I can't connect to it.
Any idea what goes wrong?
Wilberforce
I don't use mysqueezebox.com but do you have to open port 3483 (tcp)?
Are you trying to login to an existing account or create a new one? The account creation did not work for me but I can successfully login.
Is this something you've had working before?
kroonen
Post by kroonen »
I already have an acccount , and use the ubuntu 12.04 version with squeezeplay installed it works fine
Wilberforce
Can't reproduce this. You could try enabling the logs to see if it outputs anything useful - just change the redirect in ~/.bashrc or /opt/squeezeplay/bin/squeezeplay.sh.
kroonen
Post by kroonen »
After installing an logitech media server and selected the in squeezeplay it works. The only thing isn't wokring after rebooting the joggler it doesn't connect automatic to my accesspoint
Wilberforce
I'll check that out. Could you confirm you have auto reconnect enabled in the applet? This should also show up as:
auto_reconnect = True
in /etc/wicd/manager-settings.conf.
Edit: Just tried - looks like a bug. I'll look into it.
Wilberforce
Tracked it down... Need to set the wireless network property "automatic" to True for each wireless network you want to autoconnect to. I'll add a toggle on the "Wireless Setup" screen. If you want a quick fix you can add:
 automatic = True
to the appropriate section in /etc/wicd/wireless-settings.conf
Wilberforce
I've made a patch and was wondering if you could test?
cd /opt/squeezeplay/share/jive/applets
patch -p1 < [path to patch]/0001-Added-auto-reconnect-toggle-to-WirelessSetup.-Save-W.patch.txt
Then on the "WirelessSetup" screen (where you set IP and connect), you should be able to toggle the auto reconnect flag.
(2.3 KiB) Downloaded 426 times
kroonen
Post by kroonen »
Him
The patch works, it's now reconnecting after a reboot
regards Richard
Wilberforce
kroonen wrote:Him
regards Richard
Thanks for testing.
For everyone else: I'll update the opening post with a new image at some stage ( I'll make it clear its a new version), in the mean time please use the provided patch.
Wilberforce
Re: Squeezeplay image for internal mmc / usb
few small changes to save your mmc/usb key some writes:
in /etc/wicd/manager-settings.conf make sure you have:
debug_mode = False
in /etc/logrotate.d/wicd.logrotate use rotate 0, full listing:
/var/log/wicd/wicd.log {
    missingok
    notifempty
    size 30k
    rotate 0
    create 0640 root adm
these changes will mean logs are lost at each reboot
uncomment these lines in /etc/fstab:
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
tmpfs /var/tmp tmpfs defaults,noatime,mode=1777 0 0
tmpfs /var/log tmpfs defaults,noatime,mode=0755 0 0
tmpfs /var/log/apt tmpfs defaults,noatime 0 0
remove logs on mmc:
sudo rm -rf /var/log
sudo mkdir /var/log
and reboot.
Fursty Ferret
Post by Fursty Ferret »
How on earth do you copy the image to a USB stick? The operation always fails with "insufficient disk space" and there's no way to enlarge the partition.
Wilberforce
Fursty Ferret wrote:How on earth do you copy the image to a USB stick? The operation always fails with "insufficient disk space" and there's no way to enlarge the partition.
Are you uncompressing the image with 7zip/unxz first?
I've made a version of SqueezePlay for the internal MMC now - take a peek at the SqueezePlay OS topic. :)
Wilberforce
roobarb! wrote:I've made a version of SqueezePlay for the internal MMC now - take a peek at the SqueezePlay OS topic. :)
Did you rebase to 12.04 or are you still using 10.04?
Don't forget this version has my networking applet and power saving patches pre-applied :D
Sorry I never replied to this - just realised when I was looking at one of your posts!
I just used 10.04 again because I'm happy I know my way around it and it's still supported until 2015. There were a couple of extra foibles with 12.04, so I ditched it pretty much immediately. I'll probably jump on board when it reaches 12.04.2... ;)
