ok bit of a dim questions ...
before the update my joggler would not update the time correctly ( router settings etc ) so i turned off this function and entered the time manually all well and good no problem there ...now after this update i have a few issues i can not manually enter the time that i can see and it will not update, tried different ways to connect it to the internet to avoid the router but still nothing and even changed all the router settings ...
also i now have multiple icons for the same apps,not as much a problem as the time thing
help much appreciated as I'm living in 2009 at the moment
cheers
update time/icons
Re: update time/icons
Re. date/time - have a look at http://www.jogglerwiki.com/forum/viewto ... ?f=2&t=571 and see if it helps (it may not though!).
