The final version (v3.50 - April 2015) can be downloaded from here.
(Edit 11th Feb 2017 - Try https://mega.nz/#!lhZWUIQC!po8KGloXBLV4 ... FFsP3xU2W0 )
To find out about the current version, read the changelog here.
If you are a new Joggler user, check out a simple Quickstart Guide here.
CONTENTS
*That's all folks! (April 2015)
*What is PnP III?
*Final version (v3.50 - updated April 2015)
*Screenshots
*Installation instructions
*What is installed
*Useful threads
*Update old versions of PnP III to allow addition of Accuweather locations via the Webserver
That's all folks!
Regular visitors will probably have noticed a lack of updates to PnP III from April 2014 onwards. Since then, the BBC iPlayer app, Accuweather (now resurrected!) and Google Maps have all ceased working and I simply don't have the skills to get them going again (although 'The Lounge' links can quite easily be updated if anyone has the urge to play with the jogContent.xml file). I've also moved to Android devices and Roku/NowTV boxes for most of the things I previously 'Jogglered' for. You won't be surprised to know that there isn't a 'stock'/unhacked phone, tablet or set top box in the house!
I need to say a huge THANK YOU to everyone who actually 'created' PnP III (and PnP Mk II before it) - I just packaged it for the end-user! Obviously big contributors include roobarb, buzz, spoyser, pete, hawsey, gegs, dwl99, jkn, jon, castalla, jp_hero and, of course, gforums (and pretty much everyone on the top 50 forum posters). To be honest though, everyone on the forum has contributed in some way with little fixes, tweaks, requests, questions (mainly from ilovemyjoggler
It has been an amazing learning experience which started with PMJ (remember that?) before moving to Jogtools and then to the original gforums PnP and beyond. Without it I wouldn't have been able to do anything I've subsequently done on Android, NAS drives or Roku/NowTV boxes. I've also found that sleep is so overrated/unnecessary!
THANK YOU for all your support with this incredible project - I leave you (in terms of PnP III development) with final version 3.50!
What is PnP III?
Basically, it's a quick and easy way to greatly enhance the functionality and usefulness of your Joggler whilst retaining the ease of use of the original operating system!
PnP III works with pre and post May 2012 update Jogglers. It builds upon the wonderful work of gforums original PnP and my own PnP Mk II and aims to increase the functionality and usefulness of these great little gadgets with relative ease. PnP Mk II began as a little project to enable me to keep my family of Jogglers configured with what I wanted. After a couple of requests from users of this forum, the project took on a life of it's own! It is really just a collection of the works of other far cleverer folk than I. There weren't any changes or updates after April 2014, but a final release (v3.50) has been created to reflect the fact that some apps stopped working (due to external support beign removed) or needed fixing.
Current version
The final version of PnP III (v3.50 - April 2015) can be downloaded from here. (Edit 11th Feb 2017 - Try https://mega.nz/#!lhZWUIQC!po8KGloXBLV4 ... FFsP3xU2W0 )
Read the detailed changelog here.
Screenshots - mostly June 2013
Note: PnP III applied after roobarb's clean OpenPeak reflash. Most games are not on the original (blue) o2 software. Dilbert now removed from PnP III as no longer supported/functional. BBC iPlayer app and Google Maps app also removed as no longer supported/functional
Instructions
NOTE: ALL SETTINGS WILL BE LOST.
It goes without saying that I take no responsibility if anything untoward should happen to your Joggler, although fortunately there are plenty of us here who are willing to help in the unlikely event that it does!
Stage 1 - make sure the Joggler is running the latest operating system.
Use Roobarb's re-worked OpenPeak image and reflash tool. Find it at Roobarb's birdslikewires site. The advantage of this is a cleaner image and the ability to install automatically without telnet.
Stage 2 - Install PnP III
Works with Jogglers reflashed with Roobarb's cleaner post-update OpenPeak OS v30300 (recommended) or Jogglers running the original o2 OS
1) Make sure your Joggler is 'clean'.
Use the reflasher from birdslikewires.co.uk to achieve this with your preferred version.
2) Unzip the downloaded archive and copy all the files to the root a FAT32 formatted USB stick .
Make sure any hidden files are copied.
Make sure there is no 'remove_for_new_install' file on the root USB stick
3) With the Joggler turned off, plug the USB stick into your clean Joggler, switch it on and leave it to do its thing!
This method does not require network or internet connection.
This can take 10-20 minutes depending on the USB stick.
It may 'reboot' a few times but will stay on the 'OpenPeak' or 'o2' boot screen, looking for all the world as if nothing is happening. Flashing USB sticks however tell otherwise.
4) The Joggler will eventually reboot into the OS with all the new apps and icons
5) You will need to remove the 'remove_for_new_install' file from the USB stick after use to use it again.
Once installation is complete:
SSH, SCP, Telnet enabled(username: joggler password: joggler)
Simple Webserver available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS>
Logitech Media Server (LMS) available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS:9000>
NOTE: IF YOUR JOGGLER IS TEMPERAMENTAL AND DOESN'T RESPOND WELL (I.E. FAILS) IF REBOOTED TOO OFTEN, USE THE 'MANUAL' METHOD INVOLVING TELNET BELOW:
1) Make sure your Joggler is clean (See roobarb's reflashing instructions - linked above).
2) Unzip the downloaded archive and copy all the files to a formatted USB stick .
3) Make sure your joggler is connected to your network.
Although internet access is not required to install PnP III,
you need network access to be able to Telnet in!
4) Plug the PnP III USB stick into an updated Joggler (with it powered on).
5) Telnet into the Joggler via a computer. The username is root and there is no password.
(open <your Joggler's IP address>)
4) Type in:
cd /mnt/files <press Enter>
./pnp3op.sh <press Enter>
6) Loads of stuff will scroll up the Telnet window whilst the mods are installed.
7) The Joggler should eventually reboot into the OS with all the new apps and icons
8) If it is present, remove the 'remove_for_new_install' file from the USB stick after use.
SSH, SCP (username: joggler password: joggler) will be enabled in addition to Telnet (username: root)
Logitech Media Server available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS:9000>
What is installed?
(Please also read the changelog linked above)
*Opera Mobile 10.1 browser
*Outlook.com (Hotmail), GMail, Yahoo Mail and Twitter shortcuts (via Opera to the mobile versions of the sites)
*The Lounge Radio (allowing customisation of stations (via telnet etc) - Station url list needs updating - some won't play
*Logitech Media Server installed with BBC iPlayer radio add-ons installed as well as the RadioFeeds plugin
*The ability to make Network Shares available using the Webserver web interface and access them via LMS.
*Squeezeplay (please consider donating at birdslikewires.co.uk if you find this useful)
*BBC iPlayer allowing live and on-demand TV and radio viewing over your network (watch out for your ISP usage limits!) - No longer functions
*YouTube (customisable with a little fiddling/file editing)
*UPnP (Connect and Play) - Play Shared Media with no further tweaking
*Google Calendar
*RSS News reader (customisable with a little fiddling/file editing)
*AccuWeather app - Locations can be added via the Webserver!
*Timer and Stopwatch apps
*Calculator
*Facebook app
*Flickr app
*Dilbert cartoon - No longer functions
*Several simple flash games including Angry Birds
*Google Maps - No longer functions
*GTalk (just has GTalk messaging functionality)
*Music, Video and Photos apps (can play/display from USB stick)
*Memos
*Horoscopes
*SWF Launcher including Reboot and Shutdown scripts to save pulling the plug
*One-touch install (and update) of Adblocker via SWF Launcher
*Alarm app
*Screen Off one-touch icon
*Mount Writable USB shortcut
*PDF Reader
*Squeezelite and required libs for manual launching/tinkering
*On original o2 Jogglers only: Sudoku,
*SSH, SCP and Telnet are also enabled
By modifying the install files on a USB installer, you could customise the install to suit your own needs.
Useful related threads and posts
*Add locations to Accuweather app - more info here and here.
*Radiofeeds plugin for Logitech Media Server - find out more here and here.
*Restore Squeezeplay power button default functionality (makes it Turn Off Squeezeplay rather than Exit) - instructions here.
*Using WinSCP to easily access and edit files - quick guide here.
*Running Squeezelite information is here.
*Run your own SWF apps via the instructions here.
*More information on the adblocking process - check out this post.
*How to kill rogue processes (e.g. Opera arrow on desktop) - check out this thread.
*Info on mounting cifs/samba shares can be found here, here and here.
*Original thread for the iPlayer app can be found here.
*Original thread for the YouTube app can be found here.
*Dedicated Squeezeplay thread for non-PnP III issues can be found here.
*Update 'busybox' commands on the Joggler via the instructions here.
*Want to start again? Read the reflashing thread here (for the original o2 interface) or here (for the debranded OpenPeak version).
Add Accuweather locations via the Webserver
This update means that you can just type your Joggler's IP address into a web browser on the same network, select the option to 'Add Accuweather Locations' and follow the instructions! (Installed automatically on PnP v3.50d and later)
UPDATE ACCUWEATHER ON ANY PREVIOUS VERSION OF PnP III (pre-v3.50d)
Putty/Telnet method
Telnet/Putty in to the Joggler and copy and paste the following:
cd /tmp
wget -O accuweatherfix.tar http://www.jogglerwiki.com/forum/download/file.php?id=819
tar xvf accuweatherfix.tar
mv control.txt /media/gforums/webserver/control.cgi
mv accuweather.txt /media/gforums/webserver/cgi/accuweather.cgi
rm accuweatherfix.tar
cd /tmp
wget -O weatherFile.txt http://www.jogglerwiki.com/forum/download/file.php?id=821
mv weatherFile.txt /media/app-cfg/common
Download https://www.dropbox.com/s/25z0kawoxdtgr ... l.cgi?dl=0
Use WinSCP to copy it into /media/gforums/webserver
Check the permissions are rwxrwxrwx (Right click it and select 'Properties' to change them if necessary).
Download https://www.dropbox.com/s/quvxmvk9kbawc ... r.cgi?dl=0
Use WinSCP to copy it into /media/gforums/webserver.cgi
You might need /media/app-cfg/common/weatherFile.txt too if one doesn't exist already.
Download https://www.dropbox.com/s/ar2cizq1xjjh5 ... e.txt?dl=0
Post updated 14th October 2015, 21:20
