Joggler as Wifi AP router
I've been trying to use my joggler as a wifi router - it works for WEP ad-hoc - but will all the horror stories surrounding drive-by hacking, I want to use WPA. (WPA2 is definitely unsupported in ad-hoc mode it seems).
I just can't get WPA ad-hoc to work with the internal ralink 2780 wifi card. it refuses to use encryption and runs clear.. no thanks.
so instead of just finding a card that works in ad-hoc mode for WPA - I think I want something that does full 'master' or 'ap mode'.
This looks good: http://www.ebay.co.uk/sch/i.html?_fspt= ... bx=1&rt=nc
linux has good atheros support it seems.
I'm thinking I could replace the redundant internal wifi with the flash drive (it's a tiny one) would it boot from that?
and connect the big wifi thing via the side usb port (although I'll use a hub anyway - I have one of these: http://www.hama.co.uk/053213/hama-usb-2 ... us-powered ( I got cheap on ebay )
Is anyone already using their joggler as a wifi access point?
Re: Joggler as Wifi AP router
Isn't there a kernel bug concerning ad-hoc WPA?
http://cgit.freedesktop.org/NetworkMana ... 7437b8ad39
funny - that issues links through to other issues with recent network manager which point to kernel issues. just got a patch in precise (not mine but me and a few others bringing the issue up), that the new network manager switch to nl80211 interface and some drivers didnt advertise any capabilities on that interface although they had it. including my old laptop. see https://bugs.launchpad.net/ubuntu/+sour ... bug/973241
anyway - I suspect using the joggler as an access point would be a bit crap anyway. crappy signal, bad drivers and not worth the effort for the cost of a cheap wireless access point.
Hehe,it is my dream too
and i think it will be possible
I used wifi module of joggler like AP on my XP Pc
It run in AP mode with WPA1/2 TKIP and AES (adhoc work too) I just download soft from Ralink website))
Without antenna i have nod bad signal within my room,i am sure with antenna in joggler signal can be good for 3-room flat. Perfect for Xbox iphone etc
we have
Ralink soft for XP
hostapd tool for Linux
WIfi tethers for Android
We have many chanses i think... Choose your system and try )
I have no hdd now,just android 2.2 on onboard flash,i cant test But i think it will 100% work on Linux and 90% on XP
we have
Ralink soft for XP
I dream more of russian girls than tech
*ahem*
I do think I would rather buy a £15 access point than try and get the joggler to do it though. even if it is possible.
yes,your true - girls better than tech =)BuZz wrote:I dream more of russian girls than tech*ahem*
Lets go
http://vk.com/search?c%5Bage_from%5D=18 ... 5Bsex%5D=1
amd maybe your dream become true
Due to Polish wife (aka The BOSS) I think it safest for me to keep this stuff in my imagination
I believe I have now derailed the thread too much. Apologies - back to access points!
as far as I know, xp doesn't support ap mode, only ad-hoc...Banzai wrote:Hehe,it is my dream too![]()
I used wifi module of joggler like AP on my XP Pc![]()
we have
Ralink soft for XP
What you mean - win XP for joggler or for desktop PC? XP for desktop support AP mode ! Of caurse with Ralink softphotor wrote:as far as I know, xp doesn't support ap mode, only ad-hoc...Banzai wrote:
I tried this a while back. For some reason that I was unable to figure out, Connectify won't find the WiFi hardware on my XP build... ad hoc was fine though.
I use my HTC for internet access on my laptop all the time. That said configuring a Joggler to be a combo AP / modem / WAN device wouldn't really be a major issue.
On a non Joggler tangent I just purchased 3 different combo 3G / WAN AP's this morning to test here for my failover internet access. I am also helping a friend set up some remote control to his home. He has no way to get internet access but does have 3G-4G access there.
These are the ones that I purchased to "play" with.
TP-Link TL-MR3420 ($41 USD)
http://www.tp-link.us/products/details/ ... =TL-MR3420
Sapido RB-1842 ($31 USD)
http://www.sapido.us/productrb1842o.htm
Asus RT-N13U/B ($30 USD)
http://www.newegg.com/Product/Product.a ... 6833320059
Mevi wrote:I tried this a while back. For some reason that I was unable to figure out, Connectify won't find the WiFi hardware on my XP build... ad hoc was fine though.
As i know Connectify - is only for Win 7...
Please try http://www.ralinktech.com/en/04_support ... hp?sn=5007 - Name and email can be fake
It work on my desktop XP with Jogglers usb-wlan as Access Point
download-install-right click on icon in right down corner-switch to AP mode (it use Internet Connection Sharing)
Ha ha, that's why it didn't work.
Railink sounds great. Will give it a try soon, thanks.
Pete, we get patchy 3G here in the UK and no sign of 4G, that I know about, anyway. We get screwed over here by service providers!!
Upgraded to iOS5 my iPhone now supports data tethering, which is handy but my iPad doesn't and that has the 15Gb data allowance.
