Joggler in the Bathroom
Has anyone managed to get a joggler going in the bathroom ?
Would like to know how you did it if so and also what os you are using .
A nice little photograph would also be nice if possible .
ordessa
Re: Joggler in the Bathroom
Post by ordessa »
Joking right???
240v wall-wart & water?
Then the fact that water on the screen makes the touch-screen very dicey...
Why on earth would you???
Yeah, sealing the actual; unit would not be that hard, but the power supply might give issues.
Ha ha ha, love it, you wouldn't have the power supply any where near the bathroom .
Possibly power taken from an adjacent room with only the screen visible flush mounted somewhere obviously not near the shower or bath ;-)
I have seen a few mentions of bathroom jogglers for music etc but nothing from someone that's actually done it.
I've seen flush mounted TVs in posh houses bathrooms recently, very expensive I would think, this would be a cheap alternative methinks.
I was going to give this a try after the success in the kitchen, but didn't have the time in the end. There's an empty spot above the towel rail that would be perfect. :)
ordessa
Post by ordessa »
I love this place... you guys are complete NUTS!
I like the idea - I'm currently installing a toaster in the bathroom right above the bath so i can have my morning toast while soaking.
BuZz wrote:I like the idea - I'm currently installing a toaster in the bathroom right above the bath so i can have my morning toast while soaking.
Good idea - the shower in my kitchen is next to the toaster & it makes the toast a bit soggy so I might give this a go :lol:
Well, thinking of moving a Joggler to the master bathroom. Ideally mounted into a wall. Here the room is about 4 meters by 7 meters or so. Its kind of a room in a room thing off other room in room things (walk in closets).
I want to mostly utilize it to stream internet audio (like say the BBC) or my music.
I want to keep this simple.
So the choices of OS are O2 (PnP MkII), Android ICS or Linux (Umbuntu et al).
I currently have audio as its an audio sub zone (layered down a bit from the house to the master bedroom to the master bath).
I will take the audio out to the bathroom speakers. I can provide an in wall network interface or just utilize the wireless.
What would you guys recommend as the fastest interface / software and means?
Has to meet with WAF though; she hates when I start cutting holes in walls.
I tried to cut out the middleman and just put the bare ends of a kettle lead into the bath to heat the water. I just can't understand why it keeps tripping the power off, though.
Going to put a screwdriver in place of the main RCD. Do you think that will keep the current flowing? ;)
lol - looks like a goer to me!
I have connected it up like this
https://www.dropbox.com/s/0mqvrjjpmmysk ... erconn.jpg
I thought i would take your advice and install a couple of other things in the bathroom as well
Do you think it looks ok ?
