SqueezePlay on Debian Bookworm Openframe 2 - my installation
Tried latest Debian Bookworm on my Openframe 2.
Hardware used
1 - 32Gb mini USB stick
2 - Combo Intel mini pci card (installed last year).
02:00.0 Network controller: Intel Corporation Wireless 7260 (rev 73)
1 - Wrote image to USB stick via balenaEtcher.AppImage on Linux laptop
2 - booted via USB stick
3 - configured time - timedatectl
sudo timedatectl set-timezone your_time_zone
sudo timedatectl set-timezone America/Chicago
4 - ran sudo ./of-expand - appeared to work fine. Rebooted to a crash on boot
5 - checked stick with GParted and saw that partition looked small with errors. Checked it and then it displayed full partition ext2
6 - Openframe 2 booted fine afterwards.
7 - Just hearing static when rebooting.
8 - ran sudo of-install squeezeplay - script appeared to run fine with no errors
9 - rebooted and ended with an xwindows prompt - no squeezeplay
10 - I could run squeezeplay and it would start fine.
11 - still just hearing static for sound
My quickie fix got ride of the static but still only sound via the audio jack. For me this is better than sound coming from both speaker and audio jack.
sudo nano /etc/modprobe.d/alsa-base.conf
and added this which got rid of the static.
options snd-hda-intel model=generic
12 - installing intel wifi card
apt update && apt install firmware-iwlwifi
modprobe -r iwlwifi ; modprobe iwlwifi
13 - configured yaml file with WiFi settings - rebooted
14 - sound and wifi working now but not automagically booting to Squeezeplayer and shutdown and reboot stuff not working
15 - did the sudo thing for the file named openframe_power.sh
#!/usr/bin/env bash
# openframe_power v1.11 (29th April 2020) by Andrew Davison
#  Executed by OpenFramePower applet.
if [ "$1" = "quit" ]; then
	sudo /usr/bin/xset -display :0.0 dpms 0 0 0
	[ -e /tmp/of_initial_bl ] && sudo /usr/local/sbin/of-backlight `cat /tmp/of_initial_bl` &
fi
if [ "$1" = "relaunch" ]; then
	sudo sleep 2
	sudo killall jive
fi
if [ "$1" = "reboot" ]; then
	sudo sleep 2
	sudo systemctl reboot -i
fi
if [ "$1" = "halt" ] || [ "$1" = "poweroff" ]; then
	sudo sleep 2
	sudo systemctl poweroff -i
fi
exit 0
added the following to sudoers file.
# Allow squeezeplay to run commands in /opt/squeezeplay/bin/openframe_power.sh, with no need for password
squeezeplay ALL = NOPASSWD: /bin/systemctl reboot,  /bin/systemctl reboot --no-wall -i, /bin/systemctl reboot -i, /bin/systemctl poweroff -i, /bin/ki>
16 - rebooted and all if fine.
17 - installed Webmin
Thank you Andy!!!
Re: SqueezePlay on Debian Bookworm Openframe 2 - my installation
Excellent, good work Pete , I'll have to try this out on my Open frame 2
Sent from my 2107113SG using Tapatalk
Changing out the Broadcom combo WiFi to an Intel combo WiFi worked nicely. Way back tried a Broadcom HD video card to run Kodi and stream video and it worked well with Ubuntu 14.X.
Have you a link to the one you bought Pete please
Its on Amazon for around $20 USD.
https://www.amazon.com/gp/product/B01AU ... UTF8&psc=1
Be carefull when you open the Openframe 2. I used a credit card to lift the LCD while pushing on the tabs from the inside.
Cheers Pete , does this look like the same one ?
Wireless-AC7260 7260NGW 1200M Dual-Band Wifi BT4.0 Card For T440 X240 B40 B50 Y40 Y70 Y50 FRU 04X6007 Wireless-AC7260 7260NGW 1200M Dual-Band Wifi BT4.0 Card For T440 X240 B40 https://amzn.eu/d/95Zvhyy[IMG]https://u ... 92aa4f.jpg[/IMG]
Nice tip on the wireless card, @pete - I tried for ages to get that Broadcom one to work well. It technically works, but performance was always awful unless you used the proprietary driver, which I believe is potentially problematic for me to distribute. Even then it wasn't great.
The OpenFrame 2 behind me still has a Crystal HD accelerator card in it... that was another thing I had limited success with. 🤷‍♂️
Here have a Crystal HD card and tested it versions back to work with then Kodi. (version 14 of Ubuntu??)
As of May 19, 2024 have updated Openframe 2 with no issues. All is running fine.
