Joggler has incorrect date and time
rob_rance
Post by rob_rance »
My joggler decided to lose the correct date and time and replace it with another date and time ???
I can't find how to change the date and time in the settings although I am sure that this happened once before some time ago and I was able to change it through one of the settings options ?
I am wondering if the option to correct the date and time has been lost with a firmware upgrade
Does anyone know how I can solve this , we all know that calling O2 is a waste of time !!! :evil:
Please help !!! :D
Re: Joggler has incorrect date and time
Depending on how much of a Joggler hacker you are, you could edit the file /etc/init.d/boot.d/S99boot.hacks and add the line ntpdate uk.pool.ntp.org before rebooting. This will force the Joggler to update the time from the time server on boot.
