Updating SqueezeplayOS
sixedup
Post by sixedup »
I've been running SqueezeplayOS (viewtopic.php?f=2&t=14) on the internal flash of several Jogglers for many years now. It works really well, but does hang from time to time, and is now getting very (VERY) old. I would like to update everything to newer software versions. I noticed @Roobarb! is now building i386 headless Debian Bookworm images for the Joggler, and after talking to @Man in a van I'm quite interested in adding just javalite and squeezelite to it, to keep everything as lightweight as possible.
So far, I've got Debian Bookworm from @Roobarb installed on a USB flash key installed in the side of an O2 Joggler. It works nicely.
Next I wanted to add javalite. So I followed the instructions on post 3 of this thead https://forums.slimdevices.com/forum/us ... pplication to add javalite.
SSH into the running debian install, and install build tools, git and SDL:
sudo apt update
sudo apt upgrade
sudo apt install build-essential git libsdl1.2-dev libsdl-ttf2.0-dev libsdl-image1.2-dev libsdl-gfx1.2-dev libexpat1-dev
Install luajit. Unfortunately the luajit v2.1 in the Debian repositories can't compile the javalite code (and I couldn't work out why not!) so we need to install the old 2.0 version from the lua website instead:
git clone https://luajit.org/git/luajit-2.0.git
cd luajit-2.0
make
sudo make install
sudo ldconfig
cd ..
Now install jivelite:
git clone https://github.com/ralph-irving/jivelite.git
cd jivelite
make
Now try running jivelite:
sudo /home/of/javalite/bin/javalite
The result is that the framebuffer and touchscreen are detected, and the GUI comes straight up. Nice. The cursor tracks finger movement on the touchscreen, but is significantly offset from my actual finger position (half a screen to the left, and half a screen above my actual finger position). This makes a lot of the UI unusable, but it looks like I just need to calibrate the touchscreen. How hard can that be? :lol:
I've seen comments claiming calibration success from people using TSLib, so:
sudo apt install libts0 libts-bin
I then calibrated the touchscreen using ts_calibrate:
sudo TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/input/event1 TSLIB_CALIBFILE=/etc/pointercal TSLIB_CONFFILE=/etc/ts.conf TSLIB_PLUGINDIR=/usr/lib/i386-linux-gnu/ts0 /usr/bin/ts_calibrate
xres = 800, yres = 480
Took 1 samples...
Top left : X = 2336 Y = 3808
Took 2 samples...
Top right : X = 30464 Y = 3936
Took 3 samples...
Bot right : X = 30592 Y = 29536
Took 1 samples...
Bot left : X = 2208 Y = 29824
Took 4 samples...
Center : X = 16528 Y = 16976
-6.908454 0.024773 0.000000
-8.259348 0.000042 0.014722
Calibration constants: -452752 1623 0 -541284 2 964 65536
Confguration data is also written into /etc/pointercal so it can be automatically used from now on. I then tested the calibration using ts_test:
sudo TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/input/event1 TSLIB_CALIBFILE=/etc/pointercal TSLIB_CONFFILE=/etc/ts.conf TSLIB_PLUGINDIR=/usr/lib/i386-linux-gnu/ts0 /usr/bin/ts_test
The result of this was apparently perfect; very accurate and precise tracking of the cursor to my finger on the screen. But when I tried to do the same with jivelite:
sudo TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/input/event1 TSLIB_CALIBFILE=/etc/pointercal TSLIB_CONFFILE=/etc/ts.conf TSLIB_PLUGINDIR=/usr/lib/i386-linux-gnu/ts0 /home/of/jivelite/bin/jivelite
The result was initially exactly as if I had no calibrated the touchscreen at all. However, as I continued to use it, it seemed to get somewhat more accurate. Which makes no sense. And even at its best, it was still a very clunky experience. So, how have other people succeeded with this? Did you all install X Windows (which provides calibration of the touchscreen, albeit at the price of loading a lot more software onto the machine) or did you find a better solutiion?
Re: Updating SqueezeplayOS
@sixedup
I normally install Jivelite using xserver, but here is a procedure I have just completed, without xserver, it gives jivelite, autostart at reboot using a cronjob, no cursor and calibration is out a bit. but workable.
This brings the size to
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
of@openframe:~$ df -h
udev 242M 0 242M 0% /dev
tmpfs 50M 1.8M 48M 4% /run
/dev/sda2 30G 1.4G 27G 5% /
tmpfs 246M 0 246M 0% /dev/shm
tmpfs 5.0M 8.0K 5.0M 1% /run/lock
tmpfs 192M 20K 192M 1% /tmp
tmpfs 16M 16K 16M 1% /var/log
/dev/sda1 41M 16M 26M 37% /boot
tmpfs 50M 0 50M 0% /run/user/1000
of@openframe:~$
I'm using a 32gb micro sd card in a reader (It's a bit quicker for testing purposes)
This is with
user=of
passwd=joggler
Note:
With regard to the line "make && echo joggler | sudo -S sudo make install", I use this because the sudo may timeout.
If you have changed the password then alter the word "joggler" correspondingly
I use PuTTY for SSH from a Windows 10 Desktop
SSH into the joggler and run
sudo apt update && sudo apt full-upgrade -y; sudo of-expand
When it comes back up, log in and wait for the expand to complete
sudo apt update && sudo apt install -y build-essential git libluajit-5.1-dev libsdl1.2-dev libsdl-ttf2.0-dev libsdl-gfx1.2-dev libsdl-image1.2-dev libexpat1-dev && sudo reboot
When the joggler comes back up
sudo apt update
cd
mkdir luajit
cd luajit
cd luajit-2.0
sudo ldconfig
cd
cd jivelite
sudo make PREFIX=/usr/local
sudo reboot
When the Joggler comes back up
ssh into joggler and type
sudo nano startjivelite.sh
add the following text (replace user name if different)
#!/bin/bash
export JIVE_NOCURSOR=1
Save the file by pressing Ctrl + O, and press enter, and exit using Ctrl + X
Make it executable
sudo chmod -R 755 startjivelite.sh
Then set the crontab for start-up
sudo crontab -e
(select option 1 )
add at the botttom (change user name and location if different)
@reboot /home/of/startjivelite.sh
sudo reboot
ronnie
I do get some album art (playing BBC 6 at the moment) but further testing is required
Note: it is possible to put the install and build instructions into a bash file (maybe with a small alteration here and there) and run that, then do the startjivelte.sh file and cronjob.
Album art changing ok so far, it seems to need to "warm up"
If one want to add xserver;
Do,
sudo apt update && sudo apt install -y xinit xserver-xorg && sudo reboot
and change the startjivelite bash file to
#!/bin/bash
sudo -E xinit /home/of/jivelite/bin/jivelite
ronnie
From some old notes
Originally posted by chill View Post
- The 'Quit' option on the Jivelite home screen dumps you out of Jivelite, and in my case leaves a terminal screen with some messy video artefacts along the bottom third of the screen. I think that option should be changed to restart JiveLite, or just be removed altogether.
It's easier to just start jivelite from a script which relaunches jivelite on exit.
You can hide the Quit option, hold the Quit menu item until a popup window displays, then choose Hide from Home Menu.
Code:
#!/bin/bash
while true; do
/usr/local/bin/jivelite
sleep 1
done
- The cursor is still present for ~15 seconds before disappearing.
Before you start jivelite will prevent the cursor displaying at all.
Ralphy
For tinycore or alpine linux and jivelite without X windows, you will need to have linux frame buffer support enabled in the SDL 1.2.15 library.
Ralphy
Some further thoughts
If you want to keep it on the internal ram then I think Ralphy's Squeezeplay is the way to go.
I use an external usb stick or sd card in a reader for testing out the procedure.
I don't expand the card size, so that is always comparable to the Internal ram
so far I have it working but with poor album art integartion
Raphy has replied on your thread at slimdevices for but I don't reall understand where to insert the path.
I have it configured for no-cursor (not quite calibrated) but workable.
Audio output is easy (there is advice from Ralphy on slimdevices)
Lastly you might like to read this thread, Chill did the install as Root but I don't think that is "best practise"
https://forums.slimdevices.com/forum/us ... ost1366446
It does work on Bookworm (well I had it sort off working, as i missed bits out)
ronnie
sixedup
Post by sixedup »
Man in a van wrote: Sat Jul 08, 2023 11:42 am
<snip>
Just a quick check, are you deliberately installing libluajit-5.1-dev (that will pull in libluajit-5.1-2 and libluajit-5.1-common, ie all the luajit code) from the Debian repository, as well as installing it all manually from the luajit git? When I saw the Debian version is more recent (2.1 vs 2.0 from that git repo) I hoped I could use that rather than the git version (I always prefer the distribution version) but when I tried to use it, I found that it checks the language syntax more stringently, and wouldn't compile jivelite, so I removed the distribution version and went back to the git version, which seemed enough on its own. I assume with both installed you are only using one of them, presumably the git version, as you don't mention any compilation issues. But personally I'd be wary of having both installed...
<snipped chrontab stuff>
Since we've got systemd in Bookworm it makes sense to create a "jivelite unit" and then we can make the operating system manage jivelite. It can do nice things like automatically restart it if it dies unexpectedly. I'll write up how in a separate post.
Man in a van wrote: Sat Jul 08, 2023 11:42 am I do get some album art (playing BBC 6 at the moment) but further testing is required
Yes, album art and station idents are working fine on my install too. My only problem is the touchscreen is only barely usable at the moment :(
So I think if I summarise the situation, you've installed pretty much the same way as me. We're both depending on the Debian touchscreen driver to detect the touchscreen and make it available to SDL (as an /dev/input/event device). But your setup gives a functional UI, whereas mine leaves the touchscreen calibration miles off, at least sometimes. >sigh<
I also tried adding TSLib to my stack, which in theory allows me to filter the touchscreen events and apply further calibration. But I couldn't see much difference with or without it, and in the end I wasn't sure if I was getting jivelite (or the SDL layer it uses) to actually use TSLib, and unfortunately documentation (and comments in the jivelite code) isn't exactly plentiful on this stuff.
I've got some free time this coming week, so I'll see if I can dig into the code and try to get up to speed with how the various layers interact.
sixedup
Post by sixedup »
Man in a van wrote: Sat Jul 08, 2023 11:45 am If one want to add xserver;
Thanks; was hoping to avoid this if possible :)
sixedup
Post by sixedup »
Man in a van wrote: Sat Jul 08, 2023 11:47 am From some old notes
Code:
#!/bin/bash
while true; do
sleep 1
done
Systemd will solve all that for us. Will write it up...
Ralphy
Actually, setting that environment variable to anything seems to hide the cursor - I confused myself for a while trying to set it to 0 and 1 to enable or disable it, and both made the cursor hidden!
Ralphy
I've yet to use either of those distributions in anger, so not going to worry about them yet. The comment about framebuffer support in SDL1.2 is interesting, but as far as I can tell its either compiled in or not. SDL then makes use of whatever is the "best" interface that is available to it. So in our case (with everything compiled in) when running without X, we use fbcon. But if X is available, SDL will use X in preference (as its normally higher performance)
sixedup
Post by sixedup »
Man in a van wrote: Sat Jul 08, 2023 11:59 am Some further thoughts
Maybe. Its what I'm used to with Roobarbs SQPOS ... but I thought I'd try jivelite/squeezelite too before just going with what I knew :)
Ditto.
Album art is actually working fine for me, once I win the fight to get it connected to a player...
Will go back and check that out, thanks
Thanks - will take a read of that too.
@sixedup
Well the first thing to say, is that you obviously know a lot more than I do :)
I don't know much about linux of any sort, if I find something that works' I stick with it.
This is how I install Squeezelite to use the joggler internal speaker
wget -O squeezelite.tgz https://sourceforge.net/projects/lmsclients/files/squeezelite/linux/squeezelite-1.9.9.1421-i686.tar.gz
sudo tar -C /usr/bin -zxvf squeezelite.tgz
rm squeezelite.tgz
cd /lib/systemd/system
sudo touch squeezelite.service
sudo nano squeezelite.service
[Unit]
Description=start squeezelite
After=multi-user.target
[Service]
ExecStart=/usr/bin/squeezelite -n joggler -e dsd -o hw:CARD=MID,DEV=0
User=of
[Install]
WantedBy=multi-user.target
sudo systemctl daemon-reload
sudo systemctl enable squeezelite.service
sudo systemctl start squeezelite.service
This seems to work
If I try the same thing with a jivelite.service file it dies
Loaded: loaded (/lib/systemd/system/jivelite.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-07-09 08:40:01 BST; 22s ago
Duration: 264ms
Process: 620 ExecStart=/home/of/startjivelite.sh (code=exited, status=255/EXCEPTION)
Main PID: 620 (code=exited, status=255/EXCEPTION)
CPU: 258ms
Jul 09 08:40:01 openframe systemd[1]: Started jivelite.service - start jivelite.
Jul 09 08:40:01 openframe startjivelite.sh[621]: JiveLite 0.1.0
Jul 09 08:40:01 openframe systemd[1]: jivelite.service: Main process exited, code=exited, status=255/EXCEPTION
Jul 09 08:40:01 openframe systemd[1]: jivelite.service: Failed with result 'exit-code'.
I have always returned to the cronjob, which works
I did a quick search on "status=255/EXCEPTION" and it seems related to the available ram.
I'll welcome any advice on systemctl and its use, I really only use it for Squeezelite and Librespot on raspberry pi
In Chill's link he uses a different method to start, but iirc that is Squeezeplay
I have added xinit xserver-xorg to this install and calibration is much better.
I have noticed that the Joggler does not repond well to multiple corrections via the command line, I think that this is a combination of the low ram, the flash maybe wearing and the actual OS.
If one installs a Debian Bookworm (i686) using the expert install, on a low powered computer there are more basic packages and options installed. It's an aproximatimate base of 1.2gb as opposed to 650 MB (or thereabouts)
This is a much trimmed version, although very welcome :) :)
Also Bookworm is not keen on using xserver, I think Bullseye is the better version for that
I'm also of the opinion that a good usb stick is better, it's much faster and saves the internal ram, which is why I think Squeezeplay is the way for an install on the Internal
ronnie
sixedup
Post by sixedup »
Man in a van wrote: Sun Jul 09, 2023 10:12 am @sixedup
No, I just know different stuff :)
Not a bad approach at all!
This is very helpful thanks - I suspect it's going to be where I end up - getting jivelite working (well) isn't proving simple.
   Duration: 264ms
        CPU: 258ms
I have it partially working, but something is not quite right. My service file is:
[Unit]
Description=Jivelite
After=network.target
Requires=network.target
[Service]
Type=exec
User=root
Group=root
WorkingDirectory=/home/of/jivelite/bin
Environment="JIVE_NOCURSOR=1"
ExecStart=/bin/sh -c "/home/of/jivelite/bin/jivelite"
ExecStop=/bin/sh -c "/usr/bin/killall jivelite"
Restart=on-failure
[Install]
It auto-starts perfectly when I boot the Joggler.
I can stop it with:
sudo systemctl stop jivelite
and Jivelite terminates, but doesn't seem to release the framebuffer, as the Jivelite GUI is left on the screen. When I then try to restart it, by either
sudo systemctl start jivelite
or
sudo /home/of/jivelite/bin/jivelite
the jivelite processes all start up, but it doesn't get control of the framebuffer, so there is no GUI. From what I can tell it looks like it is getting stuck trying to register event listeners with SDL, which makes me think its not fully cleaning up after itself when it terminates.
BUT, if instead I terminate it with
sudo killall jivelite
then it terminates cleanly and releases the framebuffer (which reverts to a logintty), and then systemd automatically restarts jivelite, which restarts successfully to a working GUI again. Since that is the same "stop" command that systemd should be using, I'm not quite sure why I see a different outcome to the
command :(
Similarly, if I start and stop jivelite with the commands
sudo /home/of/jivelite/bin/jivelite &
and
then everything works properly and repeatedly. So my suspicion is something associated with the systemd execution environment is preventing SDL from shutting down cleanly. Maybe :?
That method should work for jivelite too.
I'm not sure what you mean?
Still very functional compared to some of the really tiny distros though :)
@sixedup
Thanks for the jivelite.service script
I installed it on a Bookworm image that I built using "of" as the user.
"of" seems also to be "root", well anyway, your script works.
of@openframe:~$ sudo systemctl status jivelite.service
● jivelite.service - Jivelite
Loaded: loaded (/etc/systemd/system/jivelite.service; enabled; preset: enabled)
Active: active (running) since Mon 2023-07-10 19:51:43 BST; 12min ago
Main PID: 364 (sh)
CPU: 32.293s
CGroup: /system.slice/jivelite.service
├─364 /bin/sh -c /home/of/jivelite/bin/jivelite
└─367 /home/of/jivelite/bin/jivelite
Jul 10 19:51:43 openframe systemd[1]: Starting jivelite.service - Jivelite...
Jul 10 19:51:43 openframe systemd[1]: Started jivelite.service - Jivelite.
Jul 10 19:51:44 openframe sh[367]: JiveLite 0.1.0
Jul 10 19:56:12 openframe sh[367]: libpng warning: iCCP: known incorrect sRGB profile
of@openframe:~$
I find the Album art from the BBC Sounds is a bit variable, but most of the other streams seem OK.
I'll have to do more testing.
Squeezelite running OK
of@openframe:~$ sudo nano /lib/systemd/system/squeezelite.service
of@openframe:~$ sudo systemctl daemon-reload
sudo systemctl status squeezelite.service
Created symlink /etc/systemd/system/multi-user.target.wants/squeezelite.service → /lib/systemd/system/squeezelite.service.
● squeezelite.service - start squeezelite
Loaded: loaded (/lib/systemd/system/squeezelite.service; enabled; preset: enabled)
Active: active (running) since Mon 2023-07-10 19:55:15 BST; 202ms ago
Main PID: 603 (squeezelite)
CPU: 40ms
CGroup: /system.slice/squeezelite.service
└─603 /usr/bin/squeezelite -n joggler -e dsd -s 192.168.1.134 -o hw:CARD=MID,DEV=0
Jul 10 19:55:15 openframe systemd[1]: Started squeezelite.service - start squeezelite.
of@openframe:~$ alsamixer
of@openframe:~$
/dev/sda2 15G 1.4G 13G 10% /
tmpfs 192M 16K 192M 1% /tmp
of@openframe:~$
