Disable player
joggy
Disable player
Post by joggy »
is there an easy way to disable the player on the squeezeplay install on joggler atm? (just want to use the controller)
Paul Webster
Re: Disable player
Post by Paul Webster »
Not trivial.
However, you could replace Squeezeplay with Jivelite.
https://forums.slimdevices.com/showthre ... -a-Joggler
Re: Disable player
How funny, this is just the information I was looking for... weird. 8-)
So is this the done thing these days? Jivelite + background player (ie. squeezelite)?
Paul Webster
Re: Disable player
I suspect that most have stayed with the full SqueezePlay given it is the out-of-the-Box setup.
The 2nd hand Joggler that I have acquired over the years have all come with SqueezePlay rather than JiveLite.
I think that one reason for wanting the split was where the Joggler was only being used as a controller and the user did not want the extra player from SquuezePlay being listed in LMS.
Squeezelite has had attention over the years and gained some more capabilities and I think SqueezePlay has had no significant work on the player component.
alexis92
Re: Disable player
Post by alexis92 »
roobarb! wrote: Wed Feb 23, 2022 1:18 am How funny, this is just the information I was looking for... weird. 8-)
Nice little guide for installing Jivelite further down this thread too!
