Linux program on Joggler
sharpharp
Post by sharpharp »
I have pnp 3 installed on the o2 joggler and wanted to ask how i can install other software on it?
Which OS is pnp3, is it android or based on linux?
I want to install a linux/windows based program on it to run a usb device, so just wondering if this is possible on the pnp 3 build ?
Can't reveal what yet, but i will once i achieve my goal...
Re: Linux program on Joggler
Don't rely on the original OS, it's so old and tailored (restricted) you'll not be able to run much without a lot of hard work.
Use this instead. You'll be able to build anything you want on the back of this "blank" Ubuntu OS.
