How can I add wifi? (Joggler and Squeezeplay on Ubuntu 18.04)
DamianS
Post by DamianS »
Hi All,
I've got a Joggler all set up and working well, when plugged into the LAN.
I want to remove the LAN cable and use Wifi. How can I add the wifi name and password?
I'm using Ubuntu 18.04 (https://birdslikewires.net/debian-for-openframe), on the internal drive (https://birdslikewires.net/openframe-flash) and installed Squeezeplay with the sudo of-install squeezeplay command.
On the ...
... page, there's a method for adding wifi details as party of the install process, but only when it's installed on an external drive.
How can I add the wifi details when it's on the internal drive (and installed via the OpenFrame-Flash)?
I could install it all again if needed, but I'd prefer to add the Wifi details to the working system, if possible.
Can anyone help,
Re: How can I add wifi? (Joggler and Squeezeplay on Ubuntu 18.04)
Personally here just add the WiFi information on the Squeezeplayer GUI.
DamianS
Post by DamianS »
It doesn't seem to be available for me ...
ARJunior
Post by ARJunior »
Just ssh to Joggler and edit file /boot/network.yaml manually (SSID and WiFi password)
DamianS
Post by DamianS »
Perfect. Thanks ARJunior
