Opera screen dims - restore to bright?
sunspot
Post by sunspot »
Using native OS and Opera - the screen dims after a while and the only way to get it fully bright again is to quit Opera and return to the main menu.
Is there a fix or have I missed some way to re-brighten the screen in Opera?
Re: Opera screen dims - restore to bright?
I'm afraid I don't have an answer but I'd love to know a fix as this has been bugging me since the early days of Opera on the Joggler OS!
Do you have Plug'n'Pimp installed? If so, there is a switch to disable dimming.
Ah yes, that'll do for now! Thanks for reminding me of that one!
sunspot
Post by sunspot »
The PnP script does lots of things and my Joggler was set up like it is for "external device control" after lots of pain and effort....
Do you perhaps know exactly which part of the script cures the problem of Opera dimming after a time delay?
sunspot wrote:The PnP script does lots of things and my Joggler was set up like it is for "external device control" after lots of pain and effort....
You could also ask this question on the Plug'n'Pimp thread. I'm sure Christian (gforums) will read that one most often.
