I'm fairly new to Joggling and have an issue with the network connection.
My Joggler has PnP2 and I have it succesfully conected to my wired network and it works perfectly for its intended use, however it is not visible to other computers on the network and vice-versa. Specifically I want to use it to run Squeezeserver. I can connect to the ipaddress:9000 interface but am unable to assign the \\server\music folder in basic settings. (The server is running Windows Home Server 1)
On a related issue, I can't get the slideshow to find the Photos on the server either. Using the Connect & Play, it can see the server but I get the message 'Ensure you've allowed sharing on the device....'
Hope someone can help. Please!!
Many thanks
Tim
Networking issues
Re: Networking issues
I'm guessing that you're trying to get Logitech Media Server to see the music on the shared drives of your networked PC?
You can't use "\\server\sharename" to specify a folder shared on the network under Linux. You have to use a loadable kernel module called CIFS, which doesn't appear to be included as standard on the Joggler's native OS (and therefore PnPmkII).
Take a look at what I posted here in another thread: http://www.jogglerwiki.com/forum/viewto ... =140#p8258. Note that this will involve connecting over an SSH connection and using the command line...
