My son wanted a minecraft server up 24/7
and i didnt want to stop my pc's sleeping
anyway here's the required files for anyone who wants them
http://www.mediafire.com/?013cu6azaxb1umw
Extract it to either
/mnt to run off a usb stick
/media to run off the internal flash
type /mnt/minecraft if its on a flash drive
type /mnt/minecraft2 if its on the internal drive
you may well want screen and terminfo
which i got from here
http://pgregg.com/projects/joggler/
MineCraft Server
Re: MineCraft Server
In my case
I would ssh into the joggler
type screen
type minecraft
close putty
(my minecraft script is located in /bin)
type screen
type minecraft
close putty
That's an interesting idea - I'd never thought of using the joggler to run a Minecraft server. I currently use my main PC to host a server... Where did you get the Java version from - could this not just be copied (or ln'ed) into /usr/bin so that you don't need to keep it all in the same folder? And why are you running an offline server, out of interest? That's a bit of a security hole, unless you block the ports or use a whitelist.
Plus, you may want to use the -Xms and -Xmx parameters to limit the memory usage - I had to do this with my VPS, which also had only 512MB, or I'd get serious problems.
I may give this a try - although I'll be using Linux Mint, rather than the stock OS.
Haha this is awesome- typically I've just bought a server :O
This'll do for a LAN party me and some friends are organising in November - limited outgoing bandwidth at the place we are hosting it so if I can have one of these linked up to a network switch it'll do nicely
We should get a Joggler Owners Minecraft Server going!
Blimey... does the Joggler have the capacity to support a Minecraft server?? WOW...
Better not tell my 12 year old who runs servers for his class at school!!
-Xms -Xmx seemed to cause problems
it runs much better without it for some reason
it also runs far better off the internal storage
im running an offline server
as i only have one account
between three kids
between three kids
blc wrote:That's an interesting idea - I'd never thought of using the joggler to run a Minecraft server. I currently use my main PC to host a server... Where did you get the Java version from - could this not just be copied (or ln'ed) into /usr/bin so that you don't need to keep it all in the same folder? And why are you running an offline server, out of interest? That's a bit of a security hole, unless you block the ports or use a whitelist.
