HTML 5 - grooveshark
Jetpac
Post by Jetpac »
Does the Joggler handle HTML5?
I would like to use grooveshark and the opera browser doesn't work with the standard grooveshark too well
is there any chance of a HTML5 app thing that would be usable?
james
Re: HTML 5 - grooveshark
Post by james »
i presume you're using the default os? i don't think it can handle anything like that using the opera browser. i think you will need to either install windows or ubuntu on a flash drive - it's very easy and then you can do everything - including netflix on windows. you can also install xbmc on both ubuntu and windows and that allows you to access grooveshark database to stream files too without using their front end.
good luck!
