I can't change the date & time under the original O2 openpeak.
I've tried both network sync and manual setting with no luck.
No matter what you put in Setting -> Date or Setting -> Time the display on the top left corner stays the same.
Cannot change date & time
Re: Cannot change date & time
Fixed, all I did was following the dismantling video and tightened a bit of everything.
