Reset the Joggler
Reset the Joggler
Is there a way to reset the Joggler with two pins on the motherboard?
Initially I was thinking of an on and off switch; but a reset switch might work with the Joggler powered down via XP.
Re: Reset the Joggler
Could you not make a breakout switch from the power cord, would have the same effect would it not? as the joggler never truly powers down
Yes originally thinking of that. Looking at the options if the Joggler was mounted on/in a wall.
An Rf power plug controlled by another home automated Joggler Pete but then you would need two jogglers for that tho ;)
Thank-you hawsey
Possibility. Using poe for all of the Joggler's power connections.
