Sky Go on Joggler? Silverlight?
usb
Post by usb »
Hi there, been missing for ages and sorry to be lazy BUT does Sky Go work on the joggler? if so which software should I use?
Re: Sky Go on Joggler? Silverlight?
should work on windows on the joggler.
usb
Post by usb »
Just downloading XP img....
usb
Post by usb »
I have used win32diskimager to write image but only 02 original boots up. Strange as Usb (super Talent 8gb) was read when using Ubuntu version.
Try USB Image. I utilize both of them.
I have Microsoft Silverlight installed on my Jogglers and it works well.
http://www.alexpage.de/usb-image-tool/
usb
Post by usb »
My stupid mistake. Booting now. Good to hear Pete :)
Should run fine on the mevi sp3 builds
danfoshizzle wrote:Should run fine on the mevi sp3 builds
If you can do without the TabletPC stuff, build 1 might be better for a flash stick, avoid build 2 as it's a bit too bulky and slower to boot. :)
james
Post by james »
much as i would love to praise xubuntu.... no luck on lovefilm - which recently changed from flash to silverlight
i clicked on install silverlight - took me to microsoft page - detected linux - asked me to install moonlight - which i did (for chrome, doesn't work with firefox 8)
but sad to say, going back to lovefilm it said moonlight not supported as doesn't work with DRM protected content... which i presume is what sky go uses :(
so.. use xbmc with icefilms and sopcast instead :) :) :)
aint going to work. dont blame linux though. moonlight doesnt (cant cant since its all closed) include the DRM they use. ******* drm.
