All alternative OS: How do you Power On/Off the Joggler ?
Tommes
Post by Tommes »
Hi there,
how do you Turn On / Off your Joggler with your alternative OS ?
So far I did it so:
Power On:
Disconnect the power plug -> Wait a few seconds -> Connect the power plug -> Booting OS ...
Power Off:
Shutdown
An Idea to 'Power Off the Joggler' would be to do it with Standby, but i can't disable the
XScreenSaver (see other posting)
I would be interested to know how do you turn off your Joggler
cause the disconnecting power plug method can't be healthly for the Joggler ;-)
Greets, Tommes
Hardware: O2 Joggler/Patriot XPorter XT Rage 8GB/Medion X10 rc
Software: Xubuntu 11.10 / XBMC + YaVDR
Streaming: Seagate Dockstar/Afatech DVB-T/2xUSB-HD (incl. rsync-backup) - Debian Squeeze + YaVDR (streamdev)
james
Re: All alternative OS: How do you Power On/Off the Joggler
Post by james »
to power off, same as you i click top right - shutdown. then i switch off at the mains
to power on i switch on at the mains
if you always have your mains on then yes you will need to remove the power cable...
XP is shutdown, just as any normal PC. :)
Tommes
Post by Tommes »
and how do you 'Power On' the J. ?
With the powerplug reconnect method ?
(Disconnect & Connect again ?)
The Joggler has to have power removed, then reapplied to start again after a shutdown. There is no in-built method of cycling the power.
jazzmista
Post by jazzmista »
roobarb! wrote:The Joggler has to have power removed, then reapplied to start again after a shutdown. There is no in-built method of cycling the power.
If you are that way inclined, however, it would probably be possible to make a power cycler!
I purchased a miniature toggle switch for mounting in a small hole on the back of Joggler. I haven't mounted it yet. It still looks to be a big too large.
You can add an in-line power switch, the kind used with desk or bedside lamps.
