Plex Webtools plug-in on Raspberry Pi2 - permissions question
Post by dwl99 » Wed Feb 28, 2018 11:16 am
I have Plex Media Server running on my Raspberry Pi 2 and wanted to install the Webtools bundle. I have successfully downloaded & extracted the Webtools.bundle folder to the Plex Plugins folder:
cd '/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins'
sudo wget https://github.com/ukdtom/WebTools.bundle/releases/download/3.0.0/WebTools.bundle.zip
sudo apt-get install unzip -y
sudo unzip WebTools*
sudo rm -rf WebTools.bundle.zip
sudo chown pi:root -R ./WebTools.bundle
sudo reboot
However the plugin doesn't seem to be running. I suspect that it's something I've messed up with setting the permissions for the plugin. I'm logged in under username "pi". Can anyone help?
Thanks!
Re: Plex Webtools plug-in on Raspberry Pi2 - permissions question
Post by pete » Wed Feb 28, 2018 7:17 pm
Give permissions to everybody just to see if it works...
chmod 777 any directory you want
Post by dwl99 » Wed Feb 28, 2018 8:17 pm
Thanks Pete,
I changed the chown line to:
sudo chmod 777 ./WebTools.bundle
but still no success
Post by pete » Wed Feb 28, 2018 10:37 pm
Yes here tried Plex once on my MythTV box then removed it.
That said found a you tube video showing how to install Webtools on the RPi
[youtube]https://youtu.be/dIgrWKtzAZc[/youtube]
Post by dwl99 » Wed Feb 28, 2018 10:49 pm
Thanks, I found that too but it depends on having a pre-installed package named main-menu which I haven't been able to locate.
Post by pete » Thu Mar 01, 2018 11:13 pm
Found the source relating to using WebTools for Plex.
https://forums.plex.tv/discussion/comme ... nt_1368888
Post by dwl99 » Fri Mar 02, 2018 7:55 am
Thanks Pete, I've been there already and still cannot find the main-menu package mentioned.
cassio299
Post by cassio299 » Mon Apr 16, 2018 2:40 am
sudo reboot
Thanks!
You need to set the owner of the groupe as your self: sudo chown pi:pi -R ./WebTools.bundle
Post by dwl99 » Fri Apr 20, 2018 8:48 pm
sudo reboot
Thanks!
Thanks - unfortunately that didn't work either, WebTools still aren't showing under Plugins
