I install android 2.2.2 to joggler onboard flash using gparted from linuxmint usbstick...
Android work from onboard but i think i install it not so correctly - after reboot settings not save ,language switch to chinese,only 225 mb memory availible... Problem...
When i plug linux usb stick it not work - joggler try to boot android. and in fact not boot anything...
I think i have conflict between boot grub.efi of android in onboard and grub.efi on linux stick or between boot scripts (my knowledges in linux is poor...)
What stupid thing i do - i boot android - go to root explorer and just delit
boot.nsh
grub.cfg
grub.efi
startup.nsh
I think after this i can boot linux from usb stick without any problem and try to fix android (reinstall)
But i make a mistake - after this linux not start,Joggler show "O2" and that is all...
of caurse android not work AFTER THIS and
System Tool/Recovery
Reflashing Tool for the O2 Joggler - viewtopic.php?f=2&t=120 NOT WORK TOO
Now Joggler show O2 logo, it - junk...
maybe someone have any idea how i can fix it?
maybe i can add
boot.nsh
grub.cfg
grub.efi
startup.nsh
using any way... i have this files on my pc...
or use any reflash tool...
i will be glad for any help
and sorry me for my english
