can joggler PLAY DSD stream with a ES9028Q2M USB DAC
cszhy
Post by cszhy » Thu Nov 09, 2017 11:46 am
Hi there:
I have a USB DAC with a ES9028Q2M decoding chip which can decode up to DSD 256 stream.
but it doesn't support to connect with a mobile hard-drive .and it only support 128g usb stick for maximum.
I just wondering whether it can be connecting with the joggler and a mobile hd to steam DSD files?
if yes, how?
anyone tried before?
the following link is the dac I have
https://atoin.com/catalog/china/audio-s ... 53656.html
thanks
Johnny
Re: can joggler PLAY DSD stream with a ES9028Q2M USB DAC
Post by Man in a van » Thu Nov 09, 2017 2:29 pm
Depends on what OS you are using on the Joggler and if there is a driver for it
Post by hawsey » Thu Nov 09, 2017 8:37 pm
Man in a van wrote:Depends on what OS you are using on the Joggler and if there is a driver for it
Xubuntu would probably be the one to test on first then Squeezeplay OS after if that works .
cszhy
Post by cszhy » Fri Nov 10, 2017 5:21 am
I have Squeezeplay OS on the joggler. just don't know how to use it to steam DSD files.
seems there is no LMS with the OS
because when I try to access the ip address of my joggler with the port 9000,
there is nothing.
Post by hawsey » Fri Nov 10, 2017 8:40 am
Squeezeplay OS is built on the back of a very lightweight Xubuntu build so that it fits on the Jogglers internal memory .
If you put Xubuntu which has Squeezeplay built in to it on to a memory stick first then you can see if you can get your set up working like that first , then if you can it can't be that difficult to then apply that to the Squeezeplay OS build I'm sure Roobarb or others here would help you if you get that far .
A couple of words of advice , sometimes with Squeezeplay OS installed booting the efi usb stick is harder so you may have to reflash stock OS first , just bear this in mind in case you have problems .
Also it might be advisable to set the thermal trip point Thermal Psv = 80 so the build doesn't throttle , try it without first .
A keyboard and mouse will also be advisable .
Good luck :-)
Report back
Post by Man in a van » Fri Nov 10, 2017 10:30 am
there is nothing.
Where do you have your DSD files stored and how do you access them?
Do you have a LMS instance running on another computer or do you connect to MySqueezebox dot com.
If you want to continue with the Joggler you will need a usb stick with Squeezeplay and LMS installed.
It is one thing having a Dac which can playback DSD files but if the mfg only provides Windows or Mac drivers then unless you run LMS on either of these OS then you will be scuppered if there is no Linux support.
Have a read over here
http://forums.slimdevices.com/showthrea ... -9-and-DSD
I don't bother with DSD as it seems a complete faff to set up properly.
You can also use foobar on a Windows OS to playback DSD, google is your friend here, it might give you some experience of doing a setup.
I can't help any further, sorry, but it's not something I really know about.
Maybe a raspberry pi 3b with LMS on is a better way for you, you can use the Joggler as a controller, but even then you will need an OS than supports the DAC you intend to use.
atb
Ronnie
Post by Man in a van » Fri Nov 10, 2017 11:31 am
Just to add that to play DSD from a Joggler I used the following set-up about two years ago to play some sample DSD files from a link that I have long since lost. I think they were played backed as DOP or something (I can't remember).
A litttle google finds a link
https://www.audiostream.com/content/ayr ... comparison
So the set-up went like this
Hana usb2 hub plugged into the Joggler usb
https://www.amazon.co.uk/Hama-USB-2-0-H ... B0017X0R20
The following plugged into the hub:
A usb stick with external Squeezeplay installed.
LMS installed on the OS (start with the default and then upgrade to the latest nightly
http://downloads.slimdevices.com/nightl ... 1_i386.deb
and the EDO app installed (search on this forum).
You will also need to do some updating so also search for the folder kindly supplied by Karlek on this forum, that lets you do this.
The usb connection cable to the dac is also connected to the hub and if necessary also the hard disk containing your music files if they are not reachable on a NAS or computer.
All this can be done on a rpi3b with a lot less fuss.
You will need to maybe play with the settings in Squeezelite, which is easier on the raspberry pi.
If you have little or not much experience of doing this sort of thing it may be better to use picorePlayer OS which is pretty friendly or the Max2play OS, they both give a web based gui which is easier than using the cmd via ssh.
None of it will work if there is no driver for the dac.
atb
Ronnie.
cszhy
Post by cszhy » Fri Nov 10, 2017 3:11 pm
Good luck :-)
Report back
thanks for the advice! as I remember the PNPIII used to have LMS installed with it. maybe i can flash it back to the internal memory .
cszhy
Post by cszhy » Fri Nov 10, 2017 3:14 pm
atb
Ronnie.
thanks Ronnie, I will study the links
Post by hawsey » Fri Nov 10, 2017 5:46 pm
Good luck :-)
Report back
Yep PNP III latest update has Squeezeplay on it :-)
cszhy
Post by cszhy » Tue Nov 28, 2017 12:27 am
Good luck :-)
Report back
bad news is joggler seems can not recognize the usbdac. anyidea how to add driver to it? thanks
通过我的 8692-M02 上的 Tapatalk发言
Post by hawsey » Tue Nov 28, 2017 12:50 am
Have you tried installing it on Xubuntu with Squeezeplay built in ? That's where I would start :-)
cszhy
Post by cszhy » Tue Nov 28, 2017 5:03 am
hawsey wrote:Have you tried installing it on Xubuntu with Squeezeplay built in ? That's where I would start :-)
not yet. will have a try. where to download?
Post by hawsey » Tue Nov 28, 2017 11:23 am
You need the top one , hand built distro by BuZz who runs the forum .
https://jwills.co.uk/projects/joggler-xubuntu/download/
cszhy
Post by cszhy » Tue Nov 28, 2017 11:57 am
thanks , I'm using it now.
cszhy
Post by cszhy » Tue Nov 28, 2017 1:01 pm
Got following error message when I tried to install LMS
root@joggler:~# dpkg -i logitechmediaserver_7.9.1~1511211491_all.deb
(Reading database ... 137877 files and directories currently installed.)
Preparing to unpack logitechmediaserver_7.9.1~1511211491_all.deb ...
Unpacking logitechmediaserver (7.9.1~1511211491) over (7.9.1~1511211491) ...
dpkg-deb (subprocess): decompressing archive member: internal gzip read error: '<fd:4>: incorrect data check'
dpkg-deb: error: subprocess <decompress> returned error exit status 2
dpkg: error processing archive logitechmediaserver_7.9.1~1511211491_all.deb (--install):
subprocess dpkg-deb --fsys-tarfile returned error exit status 2
Processing triggers for ureadahead (0.100.0-16) ...
Errors were encountered while processing:
Post by hawsey » Tue Nov 28, 2017 1:41 pm
Hmm not sure where you are going wrong , I have a Joggler which Runs Squeezeplay os running LMS and Plex server ( just for music ) .This is based on top of the Ubuntu base which is the second one in the above link .
Maybe put that on a stick then install a basic desktop then LMS , build up from the base , it will be more lightweight anyway .
cszhy
Post by cszhy » Tue Nov 28, 2017 2:23 pm
hawsey wrote:Hmm not sure where you are going wrong , I have a Joggler which Runs Squeezeplay os running LMS and Plex server ( just for music ) .This is based on top of the Ubuntu base which is the second one in the above link .
yes.this xubuntu is currently running from the usb stick.
