Swap rpi for joggler(RPI Now Gone)
Hi All
Having a small clear out I have got two raspberry pi's they are both the older version one is a zero. The pi zero (NOT A W) came as a kit power supply,sd card ,flash drive,hdmi adapter,usb otg cable,usb hub with wifi in it a Broadcom one. The other pi come's in a clear case it's the 700mhz one. If interested I test them make they still work. I would swap for one joggler please if you think the swap is worth it.
Andrew
Andrew
Re: Swap rpi for joggler
Hello Andrew,
Where are you located?
Hello Pete
I am at Brompton, Northallerton uk
Hey Pete , how about I send Andrew a Joggler , he sends you the Pi 's and you send me the package you have ready for me
( hopefully a bit lighter than it was ) .
Sounds complicated but should be ok
Have'nt played this game for ages pass the parcel
Ha haAndrew1971 wrote:Have'nt played this game for ages pass the parcel
Really do not need any more RPi's here BUT can ship a package with 2 Jogglers over to hawsey (already ready for shipping).
I could open it and remove the betting Joggler from it making it a bit lighter to ship.
Note one is a regular O2 Joggler and the other is a betting Joggler with the bracket glued to the back of it.
Well too there is other stuff in the package which makes it weigh around 4 Ibs. Removing one Joggler will make it lighter.
Here have shifted / repurposed the RPi's and lately playing with a Pine64 2Gb computer and just ordered a Rock64 4 Gb computer with an eMMC drive. Runs Ubuntu 64 bit great. Not sure if it'll be a good Kodi box though.
Never heard of those machines Pete , have funpete wrote:Really do not need any more RPi's here BUT can ship a package with 2 Jogglers over to hawsey (already ready for shipping).
Currently using the Pine64 for automation software. It is doing well.
Here are pictures of the Pine64 and Rock64. The Rock64 is around the same size as an RPi. Running Ubuntu 16.04 64 bit on the Pine64 today.
Nicepete wrote:Currently using the Pine64 for automation software. It is doing well.
