Here is my updated version of PNP3 (update compiled by Craig) based upon final version v3.50 by OffbeatDave. viewtopic.php?f=2&t=555
Giving back to the Joggler community!
Joggler support only
Tested on Internal memory, but should work if run from USB
UPDATE 16-09-2017: If you are having problems starting LMS or missing perl dependencies, please re-download and install using the links below:
Download v3.60 July 2017 (Mega): https://mega.nz/#!Nnxn3aKL!5wLf7RRUagmj ... tQ35APft9U
Mirror (MediaFire): http://www.mediafire.com/file/4ig3hrxpg ... pdated.zip
Hashes for file verification:
MD5: 419E6E3E5B25DA8F365674D518586AE6
SHA1: 7BDB08013F3BBE9CE3BA8CA6B78B580D297CCC5C
See below for a whole host of configuration, squeezeplay configuration, SSL installation and more....
Note: Use this release at your own risk. Although rare, I am not responsible if your brick or damage your Joggler in the process. By applying this release all current settings and configurations will be lost.
Changes
- Added "Call home" fix (by jkn) - No more missing icons!
- Added new Wi-Fi driver. Final stable version, improved signal and reliability.
- Fixed all BBC national, BBC local and commercial station streams in the lounge radio app (Removed redundant streams)
- Modified the "News" App to include new feeds
- Removed all broken apps i.e. YouTube, Google calendar, Stars (horoscope) and Facebook
- New apps installed for BBC news, Engadget, New Scientist, PC Mag and Slashdot (RSS Based)
- Added a new basic calendar
- Added shutdown, reboot and ad-block apps by default
- Set new default app order
Screens
Sorry about the image quality. I had to take the pics using a camera phone.
Installation
Installation is the same as the normal PNP3 install, so you need to reset back to the original OpenPeak image before applying PNP3.
(Instructions from OffbeatDave)
NOTE: ALL SETTINGS WILL BE LOST.
It goes without saying that I take no responsibility if anything untoward should happen to your Joggler, although fortunately there are plenty of us here who are willing to help in the unlikely event that it does!
Stage 1 - Make sure the Joggler is running the latest operating system.
Use Roobarb's re-worked OpenPeak image and reflash tool. Find it at Roobarb's birdslikewires site. http://birdslikewires.co.uk/openpeak-firmware The advantage of this is a cleaner image and the ability to install automatically without telnet.
Stage 2 - Install PnP III
Works with Jogglers reflashed with Roobarb's cleaner post-update OpenPeak OS v30300 (recommended) or Jogglers running the original o2 OS
1) Make sure your Joggler is 'clean'.
Use the reflasher from birdslikewires.co.uk to achieve this with your preferred version.
2) Unzip the downloaded archive and copy all the files to the root a FAT32 formatted USB stick .
Make sure any hidden files are copied.
Make sure there is no 'remove_for_new_install' file on the root USB stick
3) With the Joggler turned off, plug the USB stick into your clean Joggler, switch it on and leave it to do its thing!
This method does not require network or internet connection.
This can take 10-20 minutes depending on the USB stick.
It may 'reboot' a few times but will stay on the 'OpenPeak' or 'o2' boot screen, looking for all the world as if nothing is happening. Flashing USB sticks however tell otherwise.
4) The Joggler will eventually reboot into the OS with all the new apps and icons
5) You will need to remove the 'remove_for_new_install' file from the USB stick after use to use it again.
Once installation is complete:
SSH, SCP, Telnet enabled(username: joggler password: joggler)
Simple Webserver available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS>
Logitech Media Server (LMS) available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS:9000>
NOTE: IF YOUR JOGGLER IS TEMPERAMENTAL AND DOESN'T RESPOND WELL (I.E. FAILS) IF REBOOTED TOO OFTEN, USE THE 'MANUAL' METHOD INVOLVING TELNET BELOW:
1) Make sure your Joggler is clean (See roobarb's reflashing instructions - linked above).
2) Unzip the downloaded archive and copy all the files to a formatted USB stick .
3) Make sure your joggler is connected to your network.
Although internet access is not required to install PnP III,
you need network access to be able to Telnet in!
4) Plug the PnP III USB stick into an updated Joggler (with it powered on).
5) Telnet into the Joggler via a computer. The username is root and there is no password.
(open <your Joggler's IP address>)
4) Type in:
cd /mnt/files <press Enter>
./pnp3op.sh <press Enter>
6) Loads of stuff will scroll up the Telnet window whilst the mods are installed.
7) The Joggler should eventually reboot into the OS with all the new apps and icons
8) If it is present, remove the 'remove_for_new_install' file from the USB stick after use.
SSH/SCP/Telnet
Username: joggler
Password: joggler
SCP is the best way to transfer files to/from the joggler
Web configuration page
Simple webserver configuration page available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS>
Available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS:9000>
--- Configuration ---
(Instructions by Craig)
Configure Wi-Fi, Wired and IP Address settings
This step can be configured via the joggler settings “Settings, Network”.
Change hostname
SSH into joggler...
vi /etc/hostname
Press I to put vi in insert mode
Press esc to exit and type :w to write and :q to quit or together :wq to write and quit
Fix automatic screen dimming
Access the webserver config page and disable dimming… (Restart required!). Note: Also needs to be disabled on squeezeplay by setting screen to 100% under display settings (Automatic by default). It can also be disabled on the joggler screensaver settings (if required).
Auto start squeezeplay
vi /etc/init.d/rcS
Add the following to the end of the script:
sleep 60
/bin/sh /media/opt/squeezeplay/bin/squeezeplay.sh 2>&1 >/dev/null &
Customising the interface (App order)
The app order is currently personalised based on my specification, so you may wish to change the app order or remove unwanted apps:
Easy: Press and hold any icon on the home screen (GUI) and wait for the menu “Move/Remove” to be displayed.
Advanced: Modify the XML cookie file menuData.cookie in /openpeak/gui/mainmenus via SCP login. Warning: Make a backup copy first as it’s easy to corrupt the XML file.
Changing the lounge radio feeds
Feeds can be modified by editing jogContent.xml in /openpeak/gui/apps/o2_radio/
Icons can also be updated in the /icons folder
Changing the news feeds
News RSS feeds can be modified by editing configureNews.xml in /media/opt/news
Icons can also be updated in the same folder
Changing weather locations
Add locations to Accuweather app - more info: viewtopic.php?f=2&t=555&p=23943#p23958 and viewtopic.php?f=2&t=555&p=23943#p23943
Enabling Cron
You can use crontab which is already contained within busybox.new:
/bin/busybox.new crontab
1. Make the crontab directory
mkdir -p /var/spool/cron/crontabs
2. Start the cron daemon (in the background) on startup by adding the entry to starthacks()
cd /etc/init.d/boot.d
vi S99boot.hacks
Add:
./bin/busybox.new crond –b
under starthacks()
Add:
killall crond
under stophacks()
3. Add your config in crontab -e (/bin/busybox.new crontab -e) as normal. The default editor is vi
Using Ad-Block
Click the ad-block app via the interface. The latest ad-block host file will be downloaded and applied automatically.
Note: No confirmation is displayed.
--- Basic Squeezeplay configuration ---
Install SSL
SSL Perl compiled for Joggler by Craig
Download Here (Mega): https://mega.nz/#!VmZmgCJZ!Ngi5gNVw6g81 ... QpXNShEso4
Mirror (MediaFire): http://www.mediafire.com/file/h39uco9le ... ler_OS.zip
(Required for new SSL streams and audio only YouTube plugin)
Also important as more streams become SSL based (encrypted) in the future.
1. Load up SCP and connect to the joggler
2. Go to /usr/share/per5 and make a copy of that folder in case you make mistakes.
3. Download SSL for joggler and extract. Open the Folder “SSL for Joggler OS” locally
4. Copy the folders in libio-socket” and libnet-ssleay” to the correct locations on the joggler i.e. /usr/share/perl5 etc. (use the paths as defined in these folders). You will need to make some new folders (again follow the paths defined) or copy/paste the files into any existing folders. Don't overwrite any folders that already exist, simply copy the files into the folder instead. The man and doc folder is not required.
5. Make sure everything is copied over correctly and Restart the joggler
6. Upon restarting; the perl5 module will load (with the SSL update) and you will be able to access SSL streams via squeezeplay and other apps.
Update BBC iPlayer (audio only) on Squeezeplay
1. Login to the server via the web config page and access Logitech Media Server settings
2. Remove any old BBC iPlayer and iPlayer extra plugins
3. Go down to the bottom of the plugin page and enter:
4. http://downloads.sourceforge.net/projec ... -short.xml
5. Install the updated BBC iPlayer and iPlayer Extra plugins.
These work with the new streaming method (DASH) adopted by the BBC
Add YouTube (Audio only app)
You need to install the SSL plugin (see earlier info) before using the YouTube plugin. If this is not installed a message "Missing SSL" will be displayed. There is no workaround for this, as all YouTube streams are now SSL based.
1. Remove any old YouTube plugin under plugins in Logitech Media Server settings
2. Go down to the bottom of the plugins page and enter: http://downloads.sourceforge.net/projec ... epo-sf.xml
3. Install the YouTube plugin
4. Go to “advanced” and under “YouTube” (dropdown list) enter your API Key.
To get the API key (free) sign into your google account and request an API key for YouTube. See online for details.
Sorry I cannot provide my own API key, but this is pretty easy to get if you research online.
Stop UPnP/DLNA from LMS
DLNA is enabled by default and can be a little annoying (especially if no media is shared via the joggler) as it causes your joggler to be displayed on Windows 10 PC's as a DLNA device.
1. Access the Logitech Media Server settings
2. Under "plugins", uncheck the UPnP/DLNA plugin and restart LMS
This will not affect the ability to access other DLNA streams or connect to alternative LMS libraries.
Hiding and Restoring icons from the squeezebox interface
Useful if menu options are missing such as "App gallery" etc.
1. Long click on an item in the squeezeplay menu to hide it
2. To restore go to “Settings, home menu” and “Restore hidden menu items”
Extra Help
For help on PNP3 please look at the PNP3 v3.5 link: viewtopic.php?f=2&t=555
For help on squeezeplay configuration and extra plugins see the Logitech Squeezebox forum: http://forums.slimdevices.com/
--- Further Updates? ---
This will be the final updated version of PNP3 and no further updates will be released by myself. However, I may provide updates for the radio streams only (if time allows).
Unfortunately, most of the original PNP3 apps such as YouTube, BBC iPlayer, google maps, google Calendar etc. are never coming back. These applications are written in flash (actionscript 2.0) and the vast majority of flash api's have now been discontinued. YouTube is now HTML5 only.
I also can't install a new Web browser due to countless missing dependencies.
I'm also unable to update LMS due to the size increase. It will not fit on the internal memory without deleting other apps.
Furthermore, the joggler has now been replaced by the rise in tablets and smart phones, but will hopefully remain useful for many years to come.
Thanks,
Regards, Craig
