Best USB stick for Joggler?
Re: Best USB stick for Joggler?
Post by hawsey » Sat Sep 19, 2015 6:16 pm
BuZz , I had a 32 k ram pack and a Kempston Joystick plus the good old "burning" printer , it was a weird thing that had a little bent needle type thing that burnt the image on to metalised paper .
A friends Dad that worked for BT got me some from work but it was 2 inches too long but he managed to cut it down to size for me and it worked a treat :-)
I also remember the printer was the first " gadget " I fixed as the stylus thing broke but I bought the part off Sinclair and fixed it up .
Jaydee999 I always say that , if your mind gets old its game over 8-) .
Post by BuZz » Sat Sep 19, 2015 9:36 pm
aah yeh. thermal printers. I have one in the loft still I think :) http://www.worldofspectrum.org/infoseek ... id=1000012 this one.
What's old anyway? 40 is the new 30!
Post by hawsey » Sun Sep 20, 2015 8:43 am
47 tomorrow does that still count ?
Still regret selling my rubber key Spectrum and also ZX81 but they had just sat in boxes for years .
Getting a Pi 2 tomorrow , will be trying RetroPi :-)
Post by BuZz » Sun Sep 20, 2015 1:58 pm
yeh - still counts :-) I'm a youngster here then - only 39!
Can get a new old one from ebay ? zx81 are expensive though.
RetroPie - I heard good things about that - def worth a try ;-)
Post by hawsey » Sun Sep 20, 2015 10:09 pm
Birthday Pi :-)
Post by hawsey » Sun Oct 04, 2015 7:46 pm
Post by hawsey » Fri Nov 20, 2015 8:28 pm
Commodore.White
Post by Commodore.White » Mon Dec 14, 2015 9:12 am
An! I remember the days you could get 5 pennyworth of chips and still get change from a tanner! probably wrong sort of chips though.
Shame that 64gig is still too small for my mp3 collection. Still using hard disks. Despite being mechanical they seem to last a while.
Love the posts, guys.
Post by hawsey » Sun Jan 24, 2016 1:31 am
Post by hawsey » Sun Jan 24, 2016 3:57 pm
£12.59 for 64 GB Sandisk ultra fit if you use the code HOTJAN at checkout
http://www.rakuten.co.uk/shop/basecom/p ... w0hwHfgLIQ
Error
Post by Error » Tue Feb 02, 2016 3:28 pm
Hawsey our USBstick buying expert :D
Post by hawsey » Sat Mar 19, 2016 6:33 pm
I'm back :-)
£4.25 16 gig sandisc Cruzer fit ideal for our Jogglers tried and tested with SqueezeplayOS
https://mobymemory.com/uk/sandisk-cruze ... oCiaTw_wcB
Post by hawsey » Sun Oct 02, 2016 9:21 pm
Just sharing my success booting W10 from a CoreBios Joggler off one of these Lexar USB sticks so they must be fast / good for our Jogglers
https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
https://images-na.ssl-images-amazon.com ... L1500_.jpg
I went for the 32 gig one for £10.33 but the 16 Gig ones are £7.98
There didnt seem to be any black ones left so i got a blue , if it bothers me plugged in to the Joggler i will colour it in black with a permanent marker :-)
Post by hawsey » Mon Nov 28, 2016 4:23 pm
Not a USB but £25 for a SSD
https://m.mymemory.co.uk/product?p=46913
Post by pete » Fri Mar 15, 2019 2:20 pm
For a while here was using an oversized overpriced true SSD USB stick. I would install these inside and remove the wireless USB stick. I also removed the shell casing for these to fit inside of the Joggler. These did draw more power than a regular USB stick. I also modded one Joggler with another internal USB port and connected this to a micro USB to SSD ZIF card to SSD. This worked too but power hungry and a very tight fit inside of the Joggler. The issues though too with USB anything for OS on the Joggler is that the Joggler resets the power on the USB port when rebooting which plays havoc with any OS. What helps a bit too is to write a ROM to the Realtek internal Gb NIC. Note that the sold Jogglers / Openpeak devices never did have a ROM installed on the Realtek Gb internal NICs.
bencat
Post by bencat » Sun May 12, 2019 9:41 am
Just a suggestion for when flashing the Joggler as the USB is only 1.1 and seems to not like either 2.0 or 3.0 flash drives . Use one of those card reader boxes and an SD card. These are made to connect to PC's and will operate with any USB version becuse they have to be designed to be compatible with older PCs with earlier USB versions . I find this works spot on every time . If this is already been put forward in this thread then apologies for the repeat but this is a long thread and I just could read through all of it first .
Post by hawsey » Sun May 12, 2019 4:57 pm
I wonder if this would also work better for booting a live efi boot image . :-)
