Washed out screen
Davebo777
Washed out screen
Post by Davebo777 »
My Joggler was working just fine (standard OS) until a power cut and now it won't reboot.
I've managed to make one USB stick with the OpenPeak 10-06-14 image but the patient is still in v-fib.
Currently burning a second USB stick but not sure the idiot proof instructions are quite idiot proof enough for me.
Please can someone walk me through it ? Or point me in the right direction ?
Cheers, Davebo.
Re: Washed out screen
Hi Davebo , you made it over here ;-) .
Welcome to the Joggler forum .
Does the stick you made boot up ? Do you see any writing on screen at all ?
Did you use this guide ?
http://birdslikewires.co.uk/openframe-flash
Problems I have had in the past include hidden files in the .IMG.gz folder ( I use Windows ) , make sure show hidden files box is ticked in Properties .
The basic process is ,
Create the reflash stick by writing the reflash image .IMG to a USB stick .
Then look at the stick you created and in rfl-boot in reflash you need to put the .IMG.gz and the .IMG.gz.md5 together with the Openframe file you downloaded; the making sure there are no hidden file extensions .
At this stage instead of reflash with Openframe .IMG you could try SqueezeplayOs which will also boot from internal memory .
Good luck
This was solved Joggler re flashed :-)
