SqpOS 3 - Perl issues
I've run into big problems trying to install a LMS plugin. The plugin requires either Perl 5.12 or 5.20
Seems SqpOS has Perl 5.18
Any way to update Perl to 5.20 ?
Paul Webster
Re: SqpOS 3 - Perl issues
Post by Paul Webster »
Perhaps the plugin is being a bit too picky.
If it is listing a specific version that is required (near the top of one of the Perl files or perhaps in a configuration file) you could try changing it and then perform a local install.
Clearly this would break again on a update - but it might get you going.
