Joggler wiki
Joggler wiki
Can't access the wiki and need Mevi's XP tutorial, what's up
Re: Joggler wiki
I confirm here across the pond that I cannot see the Joggler Wiki today.
Here is a general Wiki outage map...
Re: Joggler wiki
Still down...hoping this doesn't have anything to do with politics ....
jogglerhase
Re: Joggler wiki
Post by jogglerhase »
.. and still down... I hope its not permanently lost ..... all that valuable information....
(I am looking for a how to to get the internal Pata running - or was it sata?)
Re: Joggler wiki
Is it not a whole Wiki outage ? I'm sure BuZz will have backed it up.
jogglerhase
Re: Joggler wiki
hawsey wrote:Is it not a whole Wiki outage ? I'm sure BuZz will have backed it up.
Is there a connection between the forums wiki and wikipedia?
I thought its only a similar setup.
In any case, std. wikipedia is up and running for me, forum wiki not...
Re: Joggler wiki
Hmm wonder what others are down .Might be worth a Pm to BuZz , don't think he's on here much ;-) helooooooo BuZz .....
jogglerhase
Re: Joggler wiki
BuZz fixed it - thanks, BuZz!!
Re: Joggler wiki
Was just caused by a webserver config change I made the other day which broke it. Nothing would be permanently lost - I have daily offsite backups, with history.
Also the wiki content is dumped daily and made available here - ftp://ftp.exotica.org.uk/pub/joggler/wiki/ along with all the files.
Re: Joggler wiki
Thanks BuZz , you are the main man , knew you would have it sorted :-)
Re: Joggler wiki
Thanks Buzz, needed the USBoot XP tutorial.
Good to know we have a copy somewhere.
Re: Joggler wiki
Thank you Buzz!
