Another UMPC
Another UMPC
Post by mickchip » Fri Oct 07, 2016 9:34 am
http://www.ebay.co.uk/itm/Black-Viliv-X ... Sw65FXuxa2
bought one these off ebay, £30.00 has wifi, Bluetooth, 3g & GPS + 1024X600 TOUCH SCREEN
Installed my lite Win10 and iGO8.
Its quite a big job to get wifi & Bluetooth working on win10 but I managed it and it's working very well.
Also has XP installed as standard.
Re: Another UMPC
Post by hawsey » Fri Oct 07, 2016 6:53 pm
i wish peoples would stop posting gadgets on here :-) Nice find Mickchip , now i want one too ha ha
Do you know if it would boot x86 Android or Remix Os Mick , is it Uefi boot do you know , also what is the battery life like ?
I fancy one for my van instead of the Joggler due to the battery issue .
Re: Another UMPC
Post by mickchip » Sat Oct 08, 2016 12:12 pm
It's a normal bios boot, same processer as the Joggler but with 1gb ram, I can boot Android x86 4.4 r5 but touch screen doesn't work and wifi doesn't work. Bluetooth does work.
Not tried Remix yet and if its anything like the Joggler it will be to slow.
Lasts around 4hrs using internet, squeezeplay and watching a movie.
Battery is removable.
Processor 1.33 GHz Intel Atom Z520
Memory 1 GB 533 MHz DDR2
Hard drive 32 GB SSD
Chipset Intel US 15
Graphics Intel GMA 500
Operating System Windows XP Home Edition SP3
Dimensions (WD) 8.3 x 4.1 inches
Height 0.88 inches
Screen size (diagonal) 7 inches
System weight / Weight with AC adapter 1.9/1.6 pounds
Category UMPC/Netbook
Re: Another UMPC
Post by hawsey » Sat Oct 08, 2016 12:45 pm
Thanks for trying Mick , it looks good , not sure if I should go for this or a Link 7 which there is a dual boot image for ,
Internal GPS would make this neater than a Linx but I would really like Android as well .
My Linx 10 worked great but I use it in a case with a keyboard and it's a bit big in the van for satnav / music player .
Re: Another UMPC
Post by mickchip » Sat Oct 08, 2016 1:52 pm
I have a Tesco Connect 7 which is exactly the same as the Linx and I have put the dual boot bios on it with Win10 & Android.
It works very well.
Re: Another UMPC
Post by hawsey » Sat Oct 08, 2016 11:19 pm
Does it have GPS built in to the Connect or will it be a USB hub / USB GPS job ?
