Tested an mSATA to ZIF mini card for Joggler 2 - working
Today tested a 1/2 sized mSATA 32Gb ZIF card to work with the Joggler just fine. Only thing is that it is too big to fit over the WLAN USB stick.
Note picture makes it look big but it is much smaller than picture.
Re: Tested an mSATA to ZIF mini card for Joggler 2 - working
This is using a Joggler with the port soldered on isn't it Pete ?
Yes.
It is the right length and width. It is too fat though.
