SqueezeOS Reboot Script
wcndave
Post by wcndave »
Sometimes (weekly) my jogglers just freeze up, and I plan to mount some in the wall and use PoE which means a reboot requires going to data cabinet and unplugging / replugging which is not very WAF friendly.
I have a NAS with an intranet site, I was thinking I could create a link which runs a script that does ssh into joggler and reboots it.
Has anyone tried or created any bash scripts which do ssh@joggler (without password prompt) and then I could modify to issue sudo shutdown -r now?
johnnygal
Re: SqueezeOS Reboot Script
Post by johnnygal »
I shut mine down at night using Putty (plink) with the command
plink -ssh joggler@<ip address> -pw <password> sudo shutdown -h now
