Juggler Usb power cable
Has anyone tried one of these , just noticed it on eBay , probably a good cheap way to power your joggler if you have plenty phone chargers knocking about .
http://pages.ebay.com/link/?nav=item.vi ... 77&alt=web
Re: Juggler Usb power cable
hawsey wrote:Has anyone tried one of these , just noticed it on eBay , probably a good cheap way to power your joggler if you have plenty phone chargers knocking about .
Whenever I have tried to use one of the phone chargers, all I get is a white screen, 2 amps does not seem enough, 4 amps is fine.
Maybe the phone chargers are not 2 AMPs?
I have seen small tiny USB chargers around that look nice but never have tried one on the Joggler. I have though used these for my cell phones and they work just fine.
I also have powered up the RPi and RPi2 and my custom GPS board with these and they are working fine.
Here only substituted for Openpeak power supplies have been 4 AMP generic 5VDC PS's.
Relating to POE using a TP-Link power injector connected to a standard POE 48VDC port has always worked for me.
Some are quoted as 3.4 A , I wonder if they would work
http://pages.ebay.com/link/?nav=item.vi ... 97&alt=web
hawsey wrote:Some are quoted as 3.4 A , I wonder if they would work
That's total output
. 1A socket ideal for mobile phones, 2.4A socket ideal for tablets.
So these cables are as much use as a chocolate fire guard :-)
hawsey wrote:So these cables are as much use as a chocolate fire guard :-)
A chocolate fire guard and a bottle of red :P
I like that.
One of the first issues I had with those mini USB power connectors on boards was mostly related to their cheap ass build. I had a few just fall off the attached circuit board. I have not seen this happen to the RPi and RPi2 yet.
I am though only using the PS's with the direct connect mini USB's on them and one with a POE. I have though too gone to just soldering power leads to the boards these days. (trusting more a glob of solder more).
The connectors get warm but haven't fallen off the RPi2 yet. I am though trying to melt an RPi2 today with one in the attic
I should maybe try putting a Joggler in the attic for kicks. Temps have gone to around 140 °F / 60 °C which truely isn't that hot anyways.
