Hi, looking for a download link for the original PnP and PnP 2, very grateful if anyone can help me out.
Thanks in advance
Looking for PnP 1 and 2
Re: Looking for PnP 1 and 2
Even I don't have a copy of PnP MkII any more and I made it! Sorry!
Download PnP III instead. It has everything from PnP and PnP Mk II that still works, plus loads of other bits too. You can edit the /files/pnp3op.sh (or pnp3o2.sh) file too to customize the install too. What was it you wanted from PnP or PnP Mk II?
Just the Screen Off and the Dimming control to use the Joggler as a Clock Radio. Seem to remember on PnP 1 that you could install only the bits you wanted, but as it's a few years ago I could be wrong.
Thanks for the reply.
Hi Alphaone,
Thanks for your PM.
Not sure if any use but I did find this lurking on my harddrive - dated April 2012
PnP Mk II Public v2.12p
Hopefully you can, if required, download from the link below.
https://drive.google.com/file/d/0B2pXl0 ... kycEE/view
Offbeatdave - My kitchen joggler is still PnPing along nicely thanks!
Thanks for your PM.
Thanks for the link, have downloaded the files and assume that I write them to the root of a formatted USB drive then plug into a powered off joggler then power on and wait.
Honestly, I can't remember and I made it.Alphaone wrote:Thanks for the link, have downloaded the files and assume that I write them to the root of a formatted USB drive then plug into a powered off joggler then power on and wait.
I know it's up to you, but there is nothing to gain from installing PnP Mk II. It is a much poorer version of PnP III with less things on it, much less functionality (e.g. no mounting of network shares, no working weather app) most of which are not current versions (e.g. Squeezeplay) or won't actually work at all. There are no options to choose what to install on this version either so PnP III really is the better of the two options to choose from.
Edit: PnP Mk II installs these non-working items:
#o2 Radio (most stations won't work)
#Squeezeplay and Squeezeserver (very old versions)
#BBC iPlayer (won't work)
#o2 Calendar(won't work)
#Sky Sports News, Sky News feeds (won't work)
#Openpeak Weather (won't work)
#Dilbert cartoon (won't work)
#o2 Messaging (won't work)
#Google Maps (won't work)
#Option to reinstate Traffic and Sky News Weather apps via SWF->Shell (won't work)
