Reflash EFI on OpenFrame2
shadow1901
Post by shadow1901 »
Hi all
I have the problem during reflash from EFI to Openframe2 device.
I received the warning, "Firmware Hub driver unavailable" and in red colour this text "The driver for the Intel Firmware Hub has not been loaded......"
Could somebody help me?
I've used different USB sticks, but always the same problem.
I want flash the Telio EFI image.
Regards Shadow1901
Re: reflash EFI to Openframe2
In reference to the Openpeak 2 are you writing about the largest one with the speakers inside or the smaller Openpeak device that looks like a Joggler?
I have reflashed both but go slow playing with the Openpeak 2 (speakers in front) because of the EFI chip being soldered into place.
