Cyanogen mod on Joggler
jim_lewis1
Post by jim_lewis1 »
I would like to be able to run an Android type environment as there are so many apps available for this OS.
I've read that the Froyo build isn't stable though and have personally found this to be the case. it runs fine for a while, you get it all set up, them it hangs on the next reboot, or falls over.
Is there any possibility to get Cyanogen mod running on thejoggler? Has anyone tried this? how would one go about it?
thanks,
jim
Re: Cyanogen mod on Joggler
No Cyanogen ,
I found 1.2.3 rock solid but it looks like the links for it are now dead .
There will however be no video working on any android builds as far as I know .
