Sqeezeplay on Joggler Problem - Help Still Not Fixed
ramtec
Post by ramtec »
I have four jooglers, 3 are stock o2 with pnpIII, the other has a 8gb usb flash card in the side and runs Xubuntu 14.04 LTS (Trusty) and I have loaded sqeezeplay from the icon on the desktop. all works ok except sometimes the album art isn't displayed although it is perfectly displayed on the stock o2 jogglers i.e. I have synced the jooglers and on all three o2 ones it displays correctly but not on the Xubuntu bulit one, the art is missing but only on some albums. The versions are completely the same 7.7.2 r9710. Anyone got any ideas?
Thought I'd fixed it but still a problem, I'm think this is a picture sizing issue? Stock o2 jogglers all dispalying correctly. I thought I'd fixed it twice, once by remvoing a duplicate album and secondly by resizing the image art as it didn't like anything square i.e. 300x300 600x600 but now the resizing isn't working.
Help
ramtec
Re: Sqeezeplay on Joggler Problem - Help Still Not Fixed
Post by ramtec »
ok, I have installed SqueezePlay OS 1.58 onto the memory card and all works fine, so I must conclude it is a problem/bug with the squeezeplay that comes already installed on the Xubuntu 14.04 LTS (Trusty) build - any change of a fix?
ramtec wrote:ok, I have installed SqueezePlay OS 1.58 onto the memory card and all works fine, so I must conclude it is a problem/bug with the squeezeplay that comes already installed on the Xubuntu 14.04 LTS (Trusty) build - any change of a fix?
I'm thinking it's probably an image library not installed by default on Xubuntu. Maybe libpng or libjpeg or libsomethingorother.
Should just be a case of using apt-get (or even the GUI tools!) to find some graphics libraries and install them.
