Squeezeplay automute "disable" after reboot doesn't work
shadow1901
Post by shadow1901 »
Hi all
I search a solution to disable permanent the automute for headphones.
With alsamixer I can change, but after a reboot from Joggler the config is enable again.
thanks for answers
Shadow1901
PS: a cool feature could be, that I can enable/disable this in the squeezeplay menu
shadow1901
Re: Squeezeplay automute "disable" after reboot doesn't work
Hi all
no solution for my problem?
My goal is, that if I pluged the headphones, the master speaker is working also.
Now I have to configure always after reboot this option via ssh "alsamixer"
Maybe it gives a solution in Squeezplay direct.
shadow1901
